Help Opening Boot (Trunk) when battery flat
Thank you, that did it. For future ref, left hand fuse box under hood, left hand front corner 15 amp fuse, furthest terminal, is connect live to battery.
Note to those saying why not use the key, if the battery is totally flat, the key does NOT work?
Thanks again
W
Thanks again
W
watto700 (06-21-2022)
G’day Winalot,
Well done on getting your boot open.
They key should always work though it needs to be turned a full 90 deg. My boot lock was frozen from lack of use and I had to spend quite a
bit of time and a lot of WD40 to get it to free up and now I use the key often to make sure the lock works freely.
Cheers,
Jeff.
Cheers,
Jeff.
Sheff928 (06-22-2022)
Just had a look around trunk key, is it mechanical as well as electrical, ie it will unlock electrically and mechanically release the trunk. If so as you suggested it needs cleaning up. Sorry if I’m being thick, I’ve little or no info on the car except what I have downloaded, only the drivers manual, which doesn’t mention it.
W
W
944play (06-23-2022)
XKR2000
09-24-2019 08:24 AM
haggis95
01-21-2011 06:08 PM
