Help....Transmission Control Module x300 VDP
Old Nov 10, 2014 | 11:59 AM
georgemcnally's Avatar
Default Help....Transmission Control Module x300 VDP
My mechanic tells me he can resolve my stalling problem with a new transmission control module....the dealer wants 1600 usd for it....a used piece for 125usd but may not be programable...has anyone experienced this problem or can you tell me where we can get a refurbished unit or a better price...???
Old Nov 10, 2014 | 03:00 PM
RJ237's Avatar
Stalling problems are often throttle body related, particularly throttle position indicator, or just a need to clean the butterfly. Is your mechanic a jaguar specialist?
A TCM with matching numbers is likely a plug and play, but a new one would definitely require a programing.
If the TCM is truly suspect, try contacting Automotive Scientific to see if they can test and repair:
Automotive Scientific Inc. Your #1 Source for ECU, TCU, ABS, EBCM, Climate Control and Speedometer Repairs
Old Nov 10, 2014 | 05:26 PM
GatorJoe's Avatar
I agree with RJ237. When I had a stalling problem I researched here and first cleaned my TB, but only noticed performance improvements when running, but the stalling continued. I then changed out my ECM relay and it solved the problem. ECM relay is outermost relay of the 3 relays behind the passenger side headlights.
Joe
95 XJ6
Old Nov 10, 2014 | 08:12 PM
sparkenzap's Avatar
If you are near Atlanta, PM me and I bet I can tell you where one is you can have for free- just take it off the car.
Old Nov 11, 2014 | 01:56 PM
Not near Atlanta
Old Nov 11, 2014 | 01:57 PM
Are you suggesting that the diagnosis i've been given is invalid?
Old Nov 11, 2014 | 01:58 PM
This problem causes the transmission fault light to come on and go into limp mode...my mechanic seems to be well schooled with Jaguars...but who knows for sure...He say he is
Old Nov 11, 2014 | 02:04 PM
GatorJoe's Avatar
My ECM relay becoming intermittent thus causing the stalling also caused my transmission to go into limp home mode. Stalling does that. Try the ECM relay.
Old Nov 11, 2014 | 07:13 PM
sparkenzap's Avatar
George:
The used module should not need programming if it matches the model (no XJR). Go for the same year if you can. And, for gosh sakes, don't do something stupid like give the dealer $1600.
Steviedee1st
Nov 28, 2023 06:32 PM
XJsc-guy
Sep 25, 2015 11:09 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
BruceG
Sep 15, 2015 05:47 AM
jaguarbill
Sep 5, 2015 11:43 AM
