Horrible noise from the wheels
Old Jun 17, 2015 | 08:21 AM
Kondro's Avatar
Default Horrible noise from the wheels
Hello, im new here so if im posting in the wrong area please let me know. I have a 1996 XJ XJ6 that i just bought a few days ago. I have never owned a Jaguar before. the engine and transmision seem to be tip top, but it has a horible noise coming from the wheel assemply area i think. so loud i cant even tell wheich wheel or wheels its coming from. i have googled and found several directions to go, thats actually how i found my way here. Anyone have any ideas? love the car, hope i didnt get in too deep.. Only paid 700$ for it.
Old Jun 17, 2015 | 08:48 AM
Torrid's Avatar
This is the wrong year model forum, but I'd check the wheel bearings. Both fronts were bad on my 2006 when I got it and it made a horrible groaning racket.
Old Jun 17, 2015 | 04:46 PM
Fraser Mitchell's Avatar
If it's a '96, you need to post in the X300 forum. Did you not test-drive the car before purchase ? As said by Torrid, look at wheel bearings first, but it sounds as if your $700 will soon need to double, or even treble. There are no cheap Jaguars, just beautiful and elegant Jaguars !
Old Jun 17, 2015 | 11:27 PM
Don B's Avatar
Originally Posted by Kondro
I have a 1996 XJ XJ6 that i just bought a few days ago. [snip]... it has a horible noise coming from the wheel assemply area i think. so loud i cant even tell wheich wheel or wheels its coming from.
Hi Kondro,
Welcome to the Jaguar Forums and congratulations on your new Jaguar.
I have moved your post from the forum for the X350 to the forum for the X300, which is the Jaguar factory project code for your 1996 XJ6.
As Torrid and Fraser have mentioned, the wheel bearings are prime suspects for loud grinding noises, especially when going around corners. Another possibility could be a worn brake pad grinding against a brake rotor, which should be easy to find by inspecting the condition of the pads at each wheel.
To check your wheel bearings, raise a corner on a jack, using the proper jack points under the side rocker panels or sill panels. With the wheel raised off the ground, grasp the tire at 12:00 and 6:00 and alternately push and pull the top and bottom and observe any excess movement in the wheel. Don't mistake tire deflection for wheel movement. Spin the wheel and listen for any grinding noises. If you detect any play in the wheel or hear any unusual noises, suspect the wheel bearing.
Let us know what you find and we'll be happy to help you move forward.
Cheers,
Don
Old Jun 18, 2015 | 10:47 PM
notthemaniusedtobe's Avatar
I've just replaced my front bearings and I'm half-way through the rear-right, finishing tomorrow with the new hub I got today.
Best advice I can give is not to panic, it's really very simple to do. And Mr DonB has posted some most impressive guides in jag-lovers with links here on the site.
Many experts and experienced amateurs here in the forum, you're in good hands Kondro.
Old Jun 21, 2015 | 06:29 PM
JonnyO's Avatar
Default Hope it's not the differential...
As other posters have mentioned the bearings are a fairly cheap/simple fix.
The diff not so much.
Best of luck.
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
raulan
Sep 10, 2015 12:43 PM
mrplow58
Sep 9, 2015 11:27 AM
innzane
Sep 2, 2015 10:08 AM
