How To Replace Front Shocks ( AfterMarket)
Old Sep 11, 2015 | 10:16 PM
al_roethlisberger's Avatar
Can anyone verify the torque value for the bolts for the shock install, top and bottom?
Old Sep 12, 2015 | 02:22 PM
JTsmks's Avatar
Originally Posted by al_roethlisberger
Can anyone verify the torque value for the bolts for the shock install, top and bottom? .
I used the German setting on the bottom "goodntite" 😉
Old Oct 5, 2020 | 10:42 PM
LouieXK's Avatar
Alternate method of removing lower shock bolt
That lower bolt will trip you up - big time.
After trying to knock out with sledge / air hammer / electric hammer / torch, also using WD-40 / Kroil / PB Blaster, and MUCH time, this bolt just would not budge.
It was rusted in place to the inner part of the bush
Sawzall made quick work of shock tab, then a handheld hacksaw blade cut into the outer shell of bush, then tapped out with drift.
The new bush must be tapped into place or with a bolt and washer arrangement as mentioned in other posts -- only can be pressed in from back to front of axle.
Highhorse
Jun 15, 2024 03:51 PM
RaceDiagnostics
Jan 15, 2022 10:01 AM
anjum
Dec 6, 2016 11:40 AM
RaceDiagnostics
Aug 23, 2015 04:48 PM
vandenplas408
Dec 11, 2014 10:59 AM
