ignition coil insides ?
Old May 27, 2013 | 07:46 AM
Satterfield's Avatar
Talking ignition coil insides ?
what goes wrong with an ignation coil ?? anyone cut it open to see ? Satterfield
Old May 27, 2013 | 09:00 AM
Doug's Avatar
I've been tempted but never have. Might be interesting
Old May 27, 2013 | 09:25 AM
WhiteXKR's Avatar
Probably wire insulation breakdown from heat and high voltage most often.
Old May 27, 2013 | 09:54 AM
I changed mine out about a month ago, just wondering if I could clean them or what,seems like a waste to chunk them, they were working,had been for a long time they are Lucus brand, Satterfield ,
Old May 27, 2013 | 04:30 PM
Suede's Avatar
The "mold" (that stuff that looks like hard wax) starts to break down opening up a path for either the primary, or secondary, coil to start arcing with the magnet which separates them. That high voltage arcing will eventually take out the portion of the coil which was previously unaffected. Generally, if the primary "upper" coil goes first, you'll experience sporadic hiccups before complete coil failure. If the secondary "lower" coil goes first, you'll experience an immediate, consistent miss on the affected cylinder.
Attached Thumbnails ignition coil insides ?-ngk_kerzenschachtspule_querschnitt_en.jpg
Old May 27, 2013 | 04:51 PM
GREAT !!!!! Thank you, Satterfield ( OLD SAILOR)
hoodun
Oct 2, 2015 10:13 PM
KarimPA
Sep 27, 2015 08:46 AM
alextoevs
Sep 20, 2015 05:21 PM
Don R
Sep 14, 2015 12:34 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
