Jaguar XJ6 - Engine Light (P1401)
Old Jul 2, 2011 | 07:46 PM
holybananas's Avatar
Default Jaguar XJ6 - Engine Light (P1401)
Hey,
I was stopped at a stop sign today and my car just randomly turned off, I restarted it with no problem. The engine light came on after that. I hooked up a code reader and it shows P1401 which relates to "DPFE Sensor Circuit High Input." Does anybody know anything about this or what the exactly problem is and how it can be fixed?
It's a 1995 Jaguar XJ6 Vanden Plas!
Many Thanks,
Mitch Cal
Old Jul 2, 2011 | 08:51 PM
sparkenzap's Avatar
The JTIS literature shows this code as "EGR position circuit out of range" Since the car quit, I assume it represents a high egr flow, so I would take the EGR valve off and clean it- well after I checked that it's wire was still connected.
Old Jul 3, 2011 | 11:13 AM
Thank you sparkenzap.
Would you happen to know where I can find the EGR valve?
Old Jul 3, 2011 | 03:17 PM
sparkenzap's Avatar
Yep, I would . It is the thing that is by the throttle body that looks lie a can about 40 mm diameter and about 125 mm long and has an electrical connector at the top.
Old Jul 4, 2011 | 01:55 PM
genoaz's Avatar
holy yep very easy to change out if you want, but can try cleaning it 1st, might get you by for awhile, but if you decide to change it out its easy 2 bolts and electricall connection, but i would also use the gasket with the screen, it stops most of the carbon. And be sure to clean the 2 holes that the EGR fits over clean all teh carbon deposit you can out of it with a good cleaner, and a round bottle type brush, you need good airflow. How long has it been since you change o2 sensor?? front 2 are very easy to change out,, backs harder, new spark plugs?? i had Check engine lite on too,,,,,,, i replace egr as the last thing, lots of carbon build up cleaned reallllll good, car drives like a dream now
Geno 95 xj6 4.0 eng
Old Jul 5, 2011 | 03:35 AM
Cadillac's Avatar
Cool, I am glad egr replacement solved your problems , we did same thing on my dad's ride as well .
Happy driving
BrentGardner
29
Dec 16, 2024 12:13 AM
rusty37
Jun 7, 2016 04:43 PM
adenshillito
Feb 17, 2016 07:05 AM
david5201u
Australia - Western
Aug 29, 2015 12:50 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
