Key Remote Fob for XJ6 XJR XJ12 X300
Old Dec 6, 2014 | 03:11 PM
  #81
roberwin02's Avatar
I have a 1995 xj6 (x300). I bought the saab 900 key fob from ebay. Put my car in learning mode, and can not get the remote to program to my car. Either button I hold down and nothing. Please help on what I'm doing wrong
Old Dec 6, 2014 | 05:05 PM
  #82
v12d6's Avatar
There are two different fob frequencies - 433 MHz and 315 MHz. The fob you use needs to match up with the frequency the car is using. I have a 1995 car and had problems getting the 433MHz fob I bought to work so I am assuming my car is 315 MHz now.
Old Dec 6, 2014 | 08:00 PM
  #83
roberwin02's Avatar
Mine is the 315 mhz, so is the fob I bought but will not program to the car
Old May 25, 2016 | 08:50 PM
  #84
ivanjunior20's Avatar
Default SLCM location on 95 XJ6
I have a 95 XJ6 and would like to double check my SLCM frequency before I buy a new FOB. My antenna is 315MHz, so should be my SLCM.
Where is the SLCM located in a 95 JX6?
Old May 26, 2016 | 04:30 AM
  #85
v12d6's Avatar
If it is in the same place as on my '95 Double Six it will be in the boot/trunk on the left side, up past the fuel filler pipe.
It is a little complicated to get to see the stickers to identify the exact model in situ - I had to remove mine from the car to get a clear view.
On the off chance you live local to me (Essex, UK) I have both a 315MHz and 433MHz fob that you could try which would identify which frequency your car uses without faffing round accessing the SLCM!
Old May 26, 2016 | 06:50 AM
  #86
v12d6, thanks a lot for offering it. I actually live a bit far (Georgia, USA).
I will try to access that area in the trunk.
Old Nov 4, 2016 | 01:28 PM
  #87
Kayvan9's Avatar
Default Key FOB replacement Buttons
Has anyone replaced their Key FOB Buttons on X300 or X305? If yes, how do we open the Key FOB to take it apart? My Buttons are worn out and I have factory Replacement Buttons. Thanks !
Old Nov 4, 2016 | 02:23 PM
  #88
Originally Posted by Kayvan9
...... how do we open the Key FOB to take it apart? ......
Welcome to the forum Kayvan9,
The information you need is in the Security System Manual for your model. Here's the relevant page:
Old Nov 4, 2016 | 07:48 PM
  #89
95Leaper's Avatar
If it's the rubber pads on the remote that your talking about then all you do is use something like a small pick or paper clip to remove the old ones and the new ones just get put on by pushing them in place and working the edge with the same small pick or clip until the seat in place.
Old Nov 4, 2016 | 09:14 PM
  #90
John Herbert's Avatar
Instead of spending a great deal of time getting nowhere with these 20 yr old remotes, might I suggest you read the attached copy of my article.
I have had this solution working most satisfactorily for over a year.
John Herbert
File Type: pdf
Old Nov 12, 2016 | 12:46 PM
  #91
Kayvan9's Avatar
Smile Key FOB replacement Buttons
Thank you so much. I will follow your instructions on replacing my Rubber Pads on the Remote.
Old Nov 20, 2016 | 01:04 PM
  #92
KWalton's Avatar
I have same model and color (almost same mileage too)!! Thanks for info on key fob cause the two I have the battery cover has fallen off and lost. Awesome tip! 😙🤗
Old Nov 20, 2016 | 01:11 PM
  #93
KWalton's Avatar
Originally Posted by knealy2
Not sure if this info has been posted before, but I could find nothing here about it.
Anyway….I could not bring myself to purchase a replacement remote for my XJ6 when I found info that the Saab 900 remote will work just like Jaguar’s.
Wasn’t sure if it would work, so found one on eBay for $20 (SAAB LTQFM433 Factory OEM KEY FOB) and took a chance, and walla! Received today and just finished programming it to the car and it works just like my old one.
Hope this helps someone else out there, I just purchased two more from the same seller!
I am new to the forum and I just wanted to say thanks for posting this info. I have the same model and color, even close mileage!! 😮🙄
Have you had any problems with your IAC motor?,
Old Nov 23, 2016 | 11:01 AM
  #94
EZDriver's Avatar
Originally Posted by RJ237
My Saab remote came yesterday and I programmed it today. $19.95 including shipping from Keyless King on ebay. It even had good batteries.
Boy you got a deal my Friend. I just tried that and the one he had was $175 well used and unique to the 95 year. I'll keep using the key.
Old Jan 17, 2018 | 09:26 PM
  #95
MPDano's Avatar
I have the 1992 Vanden Plas, what frequency is mine?
Much Thanks.
Leo
Old Jan 17, 2018 | 10:00 PM
  #96
Qvhk's Avatar
Read Post #4 of this thread. There are two frequencies for X300 in the US, 315 and 433 MHz, and the majority has 433 MHz. Mine in Hong Kong uses 314 MHz. The frequency spec is found on a small sticker on the back cover of the original key fob (if you still have one, or if the sticker is still intact), at the back of the rear window, and on the Security Lock Control Module (SLCM). Some former owners might have changed the frequency by replacing the SLCM.
Old Jan 19, 2018 | 09:35 AM
  #97
motorcarman's Avatar
Much Thanks.
Leo
You need to post in the XJ40 section!!!!
bob
Old Jan 19, 2018 | 09:48 AM
  #98
MPDano's Avatar
bob
Thanks, thought all XJ6's were the same model. I didn't see anything referencing XJ40, so I am assuming this forum (Jaguar Models ( Classics ) > XJ6 & XJ12 Series I, II & III)
Leo
Old Jan 19, 2018 | 10:00 AM
  #99
b1mcp's Avatar
No, two sections down from that one - Jaguar Models ( Classics ) > XJ40 (XJ81)
Old Jan 27, 2020 | 09:16 AM
  #100
xalty's Avatar
Originally Posted by Suede
Good News. I took a chance and purchased one of the following "Code Learning" 433mhz Fobs and it worked like a charm. But this is ONLY for those with at least one currently working Fob. Total cost $13 shipped from UK to US.
Universal Garage Door Cloning Remote Control Key Fob 433MHz Gate Copy Code New | eBay
bump from 2020, but it seems not all of these units are created equal. i’ve bought a couple and none could learn my 433’s code.
