Keyfob Batteries
Old Mar 7, 2011 | 07:55 AM
Car-Nut's Avatar
Default Keyfob Batteries
I did do a search but couldnt find an answer. Also my x300 keys are at home so cant take thw fob apart to check.
I need a new battery for the remote on searching on ebay its just bringing this up and says Jaguar only is it correct for the X300?
BRAND NEW LONG LIFE
TYPE CR2032 3volt Lithium
Also known as CR2032, DL2032, ECR2032, KCR2032, BR2032, LM2032, 5004LC, 5004LB, L14, SB-T15, EA2032C, L2032, 2032, DJ2032, KL2032, E-CR2032, KECR2032
Old Mar 7, 2011 | 08:22 AM
Straight6DOHC's Avatar
x300 handbook says CR2016 (3V Lithium)
Old Mar 7, 2011 | 11:28 AM
aholbro1's Avatar
mine has 2016 and it's working
Old Mar 7, 2011 | 02:13 PM
Oubadah's Avatar
CR2016 here, takes 2.
Old Mar 8, 2011 | 03:44 AM
Car-Nut's Avatar
2 x DURACELL 2016 CR2016 DL2016 3v LITHIUM BATTERIES - £1.58 fleabay - Bargain
Old Sep 18, 2013 | 05:44 AM
Luftwaffle's Avatar
2x Lithium 2016 in mine. Just make sure they are Lithium and NOT Alkaline. There's an awful lot of Alkalines falsely sold as 'Lithium' both on ebay and Amazon, as I had to find out when I ordered my spares. Alkalines are a lot cheaper and don't last very long.
Last edited by Luftwaffle; Sep 18, 2013 at 06:22 AM. Reason: added comment about Lithium
Old Sep 18, 2013 | 06:53 PM
Suede's Avatar
The remote needs 6volts. While the 2032 is the same diameter as the 2016, it's still only 3 volts. So you need 2 batteries to get to 6 volts & (2) 2032's are too thick to fit.
Msteiner
May 16, 2016 12:19 AM
jluckcuck
Nov 6, 2015 07:49 AM
10 XF Premium
Oct 2, 2015 09:22 PM
Swagguar
Sep 30, 2015 01:34 PM
