Knocking from the rear of the car
Old Apr 18, 2012 | 02:55 PM
Deacondolo's Avatar
Default Knocking from the rear of the car
Hello all, What bush causes the rear of the car to knock over uneven roads?
Looking in the history of my car it had in 2010 x2 Rear Shock absorbers MNA3540CD
and also x2 subframe bushes MJA2595AC
What bush do i need to order ?
Old Apr 18, 2012 | 03:57 PM
Fraser Mitchell's Avatar
Well normally it is the A-frame bushes that fail and cause knocking, but you seem to have had these done recently. The part numbers you quote are for the Sport suspension. Other thing is the top shock bushes, but again, these have been replaced.
Puzzled !
You'll just have to have it up in the air and carry out an inspection.
Old Apr 18, 2012 | 05:43 PM
Deacondolo's Avatar
The top bushes ... are they part of the shock then... not separate.. so the last owner couldn't forget to do them then ?
Old Apr 19, 2012 | 04:55 AM
Some brands of shockers come WITH required bushes, some DO NOT.
There is also a "spring seating" bushing thingy that should ALWAYS be changed whilst in there.
I note from another post you have going that this is an XJR???, so it will have a rear sway bar, and there could be the rattle/knock for sure.
Old Apr 19, 2012 | 01:19 PM
wintookit wizard's Avatar
Is it a big clunk? On one of my XJRs the transmission mount foam bushing is missing, (worn out, gone) and when i go over certain bumps the transmission bounces up and the washer that holds the (missing)bushing clunks against the cross member as the tranny bounces up. ..food for thought.
Mike
BrentGardner
29
Dec 16, 2024 12:13 AM
Stoney85
Australia - Queensland
Jun 7, 2021 11:49 PM
Spikepaga
Aug 30, 2015 12:59 PM
Sshenton1975
Aug 30, 2015 09:29 AM
dpappyp
Aug 27, 2015 06:31 AM
