Left rear door won't open using inner/outer door handle
Old Nov 22, 2012 | 11:47 AM
caldercay's Avatar
Default Left rear door won't open using inner/outer door handle
I've searched this forum for a solution, but can't find anything similar to my scenario ... if there is a post someone knows of, please point it out. Otherwise:
Not long ago, I pulled on the outer door handle to open the left-rear door and the door didn't open. I opened the right-rear door, reached across to pull on the (left rear) inner door open handle - door won't open.
After pulling on the outer door handle a number of times (in the hopes of getting the door to open), the handle is now very loose and a simple flick of a little finger can pull on the handle - it's obviously completely disconnected from the door latch mechanism.
The inner door-open-handle still works. Check the following image - when I pull on the handle, the cable pulls as expected on the piece that the red arrow points to and it rotates, but the door will not open. I've fumbled around with my fingers in that area to unlatch the door, but nothing gives. That piece that rotates obviously must "push" against the un-latch mechanism, but doesn't.
Any ideas?
Old Nov 23, 2012 | 01:39 AM
FireCrow's Avatar
what about central lock? are you sure that one works on that door? because if it doesn't you might not be able to open it because of that, if my memory serves me well
Old Nov 23, 2012 | 05:20 AM
caldercay's Avatar
Thanks for the response. Yes, lock/unlock mechanism works.
I've checked the shop manual to see how the door [un]latch mechanism works, but there isn't any detail or graphic showing how it works.
Old Nov 23, 2012 | 09:34 PM
Lumppy47's Avatar
Your problem might be with the electric locking module (in the door).I have had the same problem and the locking button would rise then go back down,I soaked the unit with wd40 and held the locking button up with a pair of pliers then used the inside handle to open the door. Once open i checked the child safety unit to make sure it was working corectly (it was). It worked well for about a week then the problem returned,I then changed the electric module and it has worked fine since then. I believe there is some corrosion inside the module that was causing the problem.
Old Nov 24, 2012 | 02:00 AM
tmoore's Avatar
I'm having the same issue with my XJR except with the Drivers side door. The dealer will fix it for a cool Grand if I can get the car there.
TM
Old Nov 24, 2012 | 11:28 AM
caldercay's Avatar
Thanks.
The locking mechanism fully unlocks as it should. To be sure, I pulled up on the knob fully ... it's fully unlocked, yet the door won't open. I may open up the right side rear door panel to see how the door-open mechanism is supposed to work.
One thing i haven't done ... i should check the microfiche i have for the car to see if there's a parts figure with the mechanism in an exploded view.
Old Mar 5, 2014 | 12:10 PM
jammapic's Avatar
Blast from the past I know, but did you ever fix this?
BrentGardner
29
Dec 16, 2024 12:13 AM
Pristine97XK8Convertible
Sep 29, 2015 02:43 AM
10 XF Premium
Sep 18, 2015 10:03 PM
plmmd
Aug 31, 2015 10:07 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
