Locked boot/trunk.
Old Sep 12, 2013 | 10:06 PM
Selsoft's Avatar
Default Easier Method
Hi all,
I was able to open a stuck trunk using a snake camera and a long screw driver.
The camera I used is ImageŽ Mini 7mm USB Flexible Inspection Camera Microscope Endoscope Borescope [I paid $37.99 on Amazon].
I was able to send the camera in through one of the license plate holes to monitor the screw driver which I maneuvered through another hole.
I have attached a picture indicating the point at which I pushed on.
By pushing at the indicated place, I was able to disengage the latch and open the trunk.
Attached Thumbnails Locked boot/trunk.-capture24.jpg
Old Sep 13, 2013 | 08:04 AM
mgb4tim's Avatar
Kind of off topic, but I bought an inexpensive borescope to look for a coolant leak - I can't believe how useful this tool is. Mine requires a computer with its 5-meter usb connection - but use a piece of 10 or 12 gu wire to guide it around and it's a job done for under $20.
Attached Thumbnails Locked boot/trunk.-untitled3_zpsa67fdd65.jpg
Old Jan 30, 2014 | 12:07 PM
Pete092559's Avatar
I have the same problem, I drilled a couple holes and can see and get the part in the pic, I can move it to the right with a screw driver but it doesn't open the trunk still! Now what? I'm ready to use the sludge hammer! Pete
Old Jan 31, 2014 | 10:28 AM
littlelic69's Avatar
See my note from 7th March last year. If the operating rods are adrift, nothing will happen!! I found that drilling the one inch diameter hole gave sufficient access to get at everything. Then you need a blanking grommet to close the hole afterwards.
philwarner
28
Jul 11, 2017 10:21 AM
jluckcuck
Nov 6, 2015 07:49 AM
millertic
Sep 30, 2015 08:11 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
