Low Oil Pressure Gauge, and warning low oil light Problem ! Help me please !
Old Aug 15, 2014 | 09:07 AM
Don B's Avatar
On a related note, since no one seems to have mentioned it yet in this thread, the use of modern lower viscosity oils seems to contribute to the gauge going to zero and the low oil pressure lamp illuminating. Using the viscosity recommended by Jaguar for one's local climate seems to help reduce these occurrences (for our warm Tennessee summers the owner's manual recommends 20W-50 for our '93).
Cheers,
Don
Old Jan 19, 2016 | 09:07 AM
JonFleming's Avatar
I have a very similar problem. The oil pressure light is almost always on and the gauge is almost always at zero. My mechanic has replaced some part, I guess the transducer, twice. Once in a while the light goes out and the needle goes up to normal, especially after my mechanic has been in the engine moving stuff around. I suspect a problem with the wiring. I've been thinking of just running my own wire (I have the schematic and can probably find the other end).
Any body know anything more about the wire that was mentioned earlier?
Old Jan 21, 2016 | 08:04 PM
cool's Avatar
Thumbs up
Originally Posted by Don B
Well, having to click on a mystery link to look up info you didn't even tell us was there isn't quite as convenient as you copying and pasting the info for the benefit of current and future readers of this thread...
No worries, I'll do it for you. Here's the info, courtesy of Bob Gauff (motorcarman):
"The 1995 X300 (V) 720001 - 746613 have the pressure transducer.
Subsequent cars were fitted with switches and the INST PACK was reprogrammed to suit."
Cheers,
Don
Thanks Don, that's the proper way to share information and should be followed by others who
wishes to share
Old Jun 30, 2018 | 08:25 AM
supra-raleigh's Avatar
Has anyone had any luck with cleaning the transducer so it operates properly?
Old Jun 30, 2018 | 10:23 AM
Don B's Avatar
The oil pressure sender is a single-wire unit so the ground path is through the engine block and engine ground strap. A common cause of malfunction is oil contamination of the threads of the sender and port in the block. Sometimes, removing the sender and thoroughly cleaning the threads in the block and on the sender will restore proper operation. You can remove the oil with a good zero-residue solvent like electronic contact cleaner (not tuner cleaner that contains a lubricant). A battery terminal brush helps clean the threads in the block port. Also clean the sender electrical connector since it tends to collect oil, coolant and other gunk.
But the sender is such a pain to access, and the newer switch-type ones are so inexpensive, that I personally will never again remove an old one without having a new one to install after cleaning the connector and the threads in the block.
Cheers,
Don
Old May 9, 2019 | 04:12 AM
Part# LNA5642CA transducer.
Will this work on a 93 XJ6?
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
johanasu
Sep 3, 2015 12:39 PM
niner nellie
Sep 1, 2015 10:53 PM
larney
Aug 27, 2015 07:54 PM
