Mr peter grove
Old Mar 29, 2020 | 05:16 AM
PETER GROVE's Avatar
Question Mr peter grove
On my XJR 6 cylinder Super Charged motor what is the Potentia Meter 's function????Would appreciate answers.
Old Mar 29, 2020 | 07:19 AM
Steve M's Avatar
Do you have a photo?
Old Apr 1, 2020 | 10:29 AM
Don B's Avatar
Hi Peter,
I assume you are referring to the Throttle Potentiometer, also know as the Throttle Position Sensor. If so, this is a variable resistance device connected to the throttle body and wired as a voltage divider. As the throttle opens and closes, the potentiometer rotates and its resistance varies, which causes the voltage signal to the Engine Control Module (ECM) to vary proportionately, so the ECM knows the degree to which the throttle butterfly valve is open or closed. This signal is critical for the management of engine fueling, ignition timing, orchestrating smooth gear shifts, etc.
The Throttle Potentiometer is Part 2 in this diagram:
Let us know if you are inquiring about a different poteniometer.
Cheers,
Don
Old Apr 3, 2020 | 04:12 AM
Thanks for the info Don.
Craig1966
Mar 10, 2020 10:30 PM
smaceng
Oct 24, 2019 04:11 PM
rwilli
Jun 2, 2011 02:59 PM
Xistnnn
Feb 18, 2009 06:20 PM
tobiashorne
Sep 30, 2008 07:01 AM
