mufflers
As far as I know.....hopefully others will chime in....the exhaust system and mufflers for an XJR/6 are the same size and shape as the normally aspirated XJ6, sport or otherwise. If that's correct, and I think it is, there should be no problem with the swap.
The rear mufflers on the XJR, however, are "3-pass" as opposed to the "2-pass" type used on the normally aspirated cars.
Your prospective purchaser is probably looking for a bit less exhaust restriction on his XJR.
baskervillema
Oct 1, 2015 06:43 PM
Woznaldo
Sep 26, 2015 11:02 AM
