My gas cap blowing off when opening
Old Aug 14, 2013 | 10:25 PM
smgdata's Avatar
Default My gas cap blowing off when opening
Idk what going on but as soon as I open the gas cap, gas and air just explode out in great force. is there a valve stuck? im afraid the thing is gonna blow up.
Old Aug 14, 2013 | 11:10 PM
Suede's Avatar
Search for "Rochester Valve". They commonly fail an can be replaced with an AC Delco variant for about $20. The member who posted the writeup was so kind as to even list the exact part# for you. Replace sooner than later as that excess pressure puts undue stress on both the fuel pump and fuel tank.
Old Aug 14, 2013 | 11:15 PM
smgdata's Avatar
searching now
Old Aug 15, 2013 | 05:49 AM
OWRltd's Avatar
I have the same issue with the gas cap under very high pressure. Just ordered AC Delco part...Thanks guys.
Old Aug 15, 2013 | 11:43 PM
smgdata's Avatar
as did I ,
I hope it works
Old Aug 19, 2013 | 10:10 PM
smgdata's Avatar
I put it in. and so far looks like it works
Old Aug 20, 2013 | 08:49 AM
OWRltd's Avatar
Received my valve today. First thing that I noticed is the markings on the valve. Tank, canister and vacuum. The vacuum is pointed in the opposite direction from the OEM valve. I needed to replace the vacuum line with a slightly longer piece in order to reach around to the other side.
Did anyone else notice this or just put the valve on backwards? So far no problems!
Old Aug 20, 2013 | 11:39 AM
jeremiahjaguar's Avatar
I originally replaced this rochester valve with the ac delco version some time back. I didnt notice any difference and it went right on, looks exactly like the oem. I have had no problems, I hope i didnt put it backwards.
kelliott
May 31, 2022 05:26 PM
Russ Graber
Feb 23, 2019 11:59 AM
hen555
Sep 7, 2015 11:13 PM
RedRider48
Sep 7, 2015 09:41 PM
Xkr x100
Sep 6, 2015 08:50 AM
