No fluid coming from reservoir
Old Nov 21, 2020 | 08:18 AM
Leon1's Avatar
Angry No fluid coming from reservoir
Tried to clean the wind shield last night coming home with my daughter. Hit lever for wipers. NO fluid appeared on the wind shield. Have nott check anything yet as I got this auto from my brother
Old Nov 21, 2020 | 08:23 AM
Leon1's Avatar
95 XJ6
Old Nov 21, 2020 | 06:41 PM
MattX350's Avatar
You are in the wrong section, as this is for the X350/X358 generation from 2003-10.
Your generation is known as the X300.
However first thing I would ask is did you hear the washer motor trying?
If no, check fuse and if that is OK check for power and earth at the washer pump whilst someone operates the switch.
If power and earth present, swap pump.
If yes, check washer fluid present and that jets are not blocked.
Old Apr 5, 2022 | 01:35 PM
Welcome again to the forums Leon1,
I've moved your question from X350 forum (XJ6 2003 - 2009) to X300 (XJ6 1995 - 1997) forum. Members here with the same model will be able to help.
Old Apr 5, 2022 | 02:11 PM
Parker 7's Avatar
There is a relay that should click by placing your finger on it
See page 17 as screen wash
You may have the optional headlight wash motor as a swapping option
Fuses on page 21
X300 1996 LWB.pdf (jagrepair.com)
you will find your other manuals in this link
Repair Manual - Jaguar Forums - Jaguar Enthusiasts Forum
You probably have the AJ16 engine
rf69
28
Jan 29, 2021 05:33 AM
hawaiianjag
Nov 18, 2012 10:19 AM
Torque59
XJ40 ( XJ81 )
Aug 2, 2012 02:07 PM
MTZGR777
Jul 25, 2011 04:58 AM
Mago304
Sep 28, 2009 08:19 PM
