not starting
Old Jun 17, 2021 | 03:37 AM
Vitochops's Avatar
Unhappy not starting
HI! May be it was already here, Jaguar XJ 6 1997, 3.2, not starting, turning key, lights on the dash coming on, but nothing happened after, engine not starting, even not trying to start, what can it be?
Old Jun 17, 2021 | 06:38 AM
Vee's Avatar
Vee
Is your battery charged. A partially discharged battery may be enough to turn the lights on in the cabin, but not the starter.
The starter could be toast as well.
Old Jun 17, 2021 | 06:40 AM
Vitochops's Avatar
thanks for replay, its new battery on it, will check starter
Old Jun 17, 2021 | 10:47 AM
countyjag's Avatar
Try the inertia switch.
Old Jun 17, 2021 | 10:48 AM
Vitochops's Avatar
can you tell location of it?
Old Jun 17, 2021 | 12:13 PM
Vee's Avatar
Vee
https://www.jaguarforums.com/forum/x...-switch-98502/
Although it's unlikely the switch. The inertia switch kills the fuel pump, so the car will try to start, but it won't turn over.
Do you have an alarm/immobilizer on the car. That could also prevent the car from even attempting to start. Not sure if your MY requires a chipped key.
Old Jun 17, 2021 | 12:59 PM
Parker 2's Avatar
There is a large starter solenoid relay that must click closed by placing your finger on it as other relays in the area click as well
This is your starting point for troubleshooting
Old Jun 18, 2021 | 03:42 AM
Vitochops's Avatar
Thats a problem, its not trying to start...
Old Jun 18, 2021 | 03:58 AM
Vitochops's Avatar
is it on the starter itself?
Old Jun 18, 2021 | 03:59 AM
Vitochops's Avatar
Old Jun 18, 2021 | 06:33 AM
AnttiM's Avatar
Starter relay posted by Parker here
Old Jun 18, 2021 | 06:38 AM
Vitochops's Avatar
thanks a lot, will try
Old Jun 18, 2021 | 06:51 AM
Parker 2's Avatar
Do not tighten the positive battery cable on the battery too tight
Fuse # 12 / 10 amp right engine bay fuse box , The # 1 fuse is on the same row and closest to the fuse box battery cable terminal post
This fuse relies on the right engine bay fuse box relay to close ( referred to as one of two ignition positive relay ) and can be swapped with the left engine bay fuse box relay ( which in reality only runs your horn )
Fuse # 3 / 25 amp left engine bay fuse box , this fuse is hot at all times
The specific starter circuit does go through the inertia switch ( reference point 7 stop sign double hash page 38 of the 1997 wiring guide ) as well as other circuits and the switch is fickle from reading and can be jumpered with a paper clip at the switch connector between the only 2 white wires
Starter solenoid relay large left # 4 allows power from the battery coble to flow through the starter motor after it extends the starter into the engine flywheel
The solenoid itself is attached to the starter in a way it won't come off without removing the starter so we hold off on that
By feeling for the relay to click closed or not splits your problem in half
You have inhibits like the gear shift lever position switch ( referred to as linier switch ) and the key chip in your key as it should have a lump in it , and a couple of other inhibits
You have a ZF4HP22 transmission which is different then the usual ZF4HP24 on the transmission itself position inhibit , it does not have a rotary switch attached to the transmission body like the ZF4HP24
But the relay clicking every time wanted is the starting point
If it does not click swap the relay with a headlight , fog , or A / C clutch relay , The base unhooks and you can flip the base over to spray some penetrating oil to free them up
Old Jun 18, 2021 | 11:36 AM
countyjag's Avatar
Jaguar seem to be under the impression that the inertia switch kills all ignition controlled circuits, including the fuel pump, going by the owners handbook.
Last edited by countyjag; Jun 18, 2021 at 11:37 AM. Reason: image not compatible with forum
Old Jun 18, 2021 | 11:38 AM
Vitochops's Avatar
many thanks for your comment, found few spare relays, hopefully it will help
Old Jun 28, 2021 | 03:41 AM
Vitochops's Avatar
Unhappy
changed relay number 4 on the diagram, no luck, still all lights on dash comes up as normal, rad fan starting, but car still not trying to start.. any more ideas?
Old Jun 28, 2021 | 04:10 AM
countyjag's Avatar
Inertia switch
Old Jun 28, 2021 | 04:32 AM
Vitochops's Avatar
Inertia switch
i saw before that its located on the rhf side under steering wheel, but cant find anything like this over there
Old Jun 28, 2021 | 10:57 AM
Parker 2's Avatar
Does the starter solenoid relay click by placing your finger on it ?
Swapped right engine bay fuse box relay ?
The inertia switch is always on the right side by the ight foot regardless if left hand or right hand steering
Old Jun 28, 2021 | 11:06 AM
Cafcpete's Avatar
For location, see here
