I have a 1996 X300 Base model, and the airbag module died and blew the fuse in the boot knocking out the complete dash. The module was replaced with a junk yard unit which was later removed when the airbag warning came on again and sent away for rebuild. put the repaired unit in and went to the local Jaguar Land Rover dealer but they cannot read nor reset the DTC's Does anyone on the forum have the computer and cable that will talk to that buss to clear the codes and make the car operational again. I am not against renting, purchasing, or borrowing such a unit with a guaranteed return.
Bob
To my knowledge, the SRS ECM is basically self-clearing. It does a check at every startup and the MIL on the dash will turn off if no more faults are registered. I don’t believe there is any easily-obtained diagnostic equipment that will clear the SRS light on these vehicles currently.
Just went thru this whole diagnostic process on my own car. Brendan’s diagnostic procedure in the sticky link at the top of the forum here is likely your best bet. I’d start there.
The fact you still have the SRS light on would appear to indicate there is still an unresolved fault. What exactly did they rebuild on the ECM?
