Odometer illumination.
Old Jan 5, 2019 | 11:40 AM
Steve M's Avatar
Default Odometer illumination.
Is there any fix for a dim odometer?
All the other dash lights work fine but the odometer is barely visible in daylight and completely blank at night.
Somebody mentioned changing bulbs but the display is LCD (like the clock) so I can't see that helping much.
Old Jan 5, 2019 | 11:59 AM
Jagboi64's Avatar
The display is backlit by 2 bulbs. It could be that the LCD itself is failing, there is no cure for that aside from a new cluster.
Old Jan 5, 2019 | 12:16 PM
Steve M's Avatar
Thanks.
Presumably, changing the bulbs is not a 5 minute job?
Is the mileage 'memory' stored in the cluster or elsewhere?
Old Jan 5, 2019 | 12:46 PM
Jagboi64's Avatar
It's not too bad to do, but the cluster needs to come out. Mileage is stored in the cluster. Maybe not a 5 min job, but not an all afternoon job either.
Old Jan 5, 2019 | 01:10 PM
Lady Penelope's Avatar
Bring the steering column all the way down and aft and turn the large round knob to the Off position before removing key
There are 2 ribbon connectors on the very back
The mileage is stored
Old Jan 12, 2019 | 06:08 AM
countyjag's Avatar
Removing the instrument cluster isnt a big job; 15 mins or so. Google for the procedure, but from memory 4 screws and 2 ribbon connectors to detach. Access to the bulbs is obvious thereafter, and I suspect that a blown bulb is all that is wrong. If it is the odometer unit, this is detachable from the cluster, and can be sourced separately.
cadrad
Jun 7, 2011 09:59 PM
Raheny
Jun 23, 2009 10:13 PM
SeismicGuy
Jan 30, 2009 10:58 AM
ilovethiscar
Jan 29, 2009 05:54 PM
sorapp
Oct 3, 2008 10:37 AM
