Oil Drain Plug specs anyone??
Old Apr 7, 2011 | 02:13 PM
MLRocafella85's Avatar
Default Oil Drain Plug specs anyone??
hi, my oil pan is starting to strip, and I am either going to have to retap my oil pan, or change it out. I would rather tap it out, does anyone know the exact specs on the stock oem drain plug on the 96 xj6? I know its a 20mm, but I need the exact specs with length and width and all. I wanna know if I should go with a larger drain plug, but my mechanic says to find out the specs first. If anyone can help, I would gladly appriciate it, thanks
Old Apr 7, 2011 | 03:41 PM
motorcarman's Avatar
20mm X 2.5 is the thread size. You can get a rethread kit but it is a bit 'pricey' and you have to get the hole and threads perpendicular to the sealing face of the pan or the drain plug will be crooked and leak.
I have done this repair several times and I usually have to remove the gearbox dipstick tube for access.
bob gauff
Old Apr 7, 2011 | 04:21 PM
hey bone, thanks for the info, where could I purchase this kit?? and I am sure its cheaper than replacing a oil pan and easier right??
Old Apr 7, 2011 | 08:15 PM
There are TIMESERTS, RECOIL and HELICOIL etc. kits with the drill bit and inserts. I think the ones I used were HELICOIL but I don't remember.
bob gauff
Old Apr 8, 2011 | 02:55 AM
Car-Nut's Avatar
I dont know the price of the kits etc.
The other option is a second hand sump off a breaker ......
Just my 2p
Old Apr 8, 2011 | 01:11 PM
hey car nut, just wondering what a second sump off a breaker is?
Old Apr 8, 2011 | 09:03 PM
I think you need to find a second hand (used) sump from a breaker (salvage yard) to avoid a thread repair.
Old Apr 10, 2011 | 05:16 PM
JackJ's Avatar
This is pretty cool, I did not realize that a rethread kit was available.
It's very interesting also the regional colloquialisms.
2nd hand seems to be a phrase used on both sides of the pond.
2p = 2pence = 2c = 2cents.
Breaker is what us yanks call a junkyard/salvage yard/used parts dealer etc...
Throw in boot, bonnet, lorry and glove and a yank could get really lost. And if you are from the southern US, as I am, don't be offended. It's my understanding that we all come under the heading of Yank to the Brits. Personally I'm a hillbilly.
It's cool to come here and learn about jags and linguistics at the same time.
Old Apr 11, 2011 | 08:03 AM
asm54's Avatar
I have used Helicoil in the past (not in this application) and their kit is very high quality, and worked flawlessly though a bit pricey
The same old saying applies "You get What you Pay For"
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
Gerard Radimaker
Sep 13, 2015 10:33 AM
teacoff
Sep 10, 2015 08:25 AM
