Oil pressure switch
Old Sep 21, 2024 | 08:33 AM
brinny's Avatar
Default Oil pressure switch
Hi all, I am new to this forum after recently purchasing an xjr6 1997. I am not new to jags or the jag forum in general and also own an x100. Could someone help me with the oil pressure switch please. I have researched it and my original is numbered lna 5642 ca. I think this was replaced by jlm20791? Can anyone confirm this please. If this is correct any suggestions to where I might purchase a reasonably priced one or other options. As always thanks in advance for your help.
Old Sep 21, 2024 | 08:41 AM
Parker 7's Avatar
I think it had to do with a TSB , looking
Old Sep 21, 2024 | 08:56 AM
Parker 7's Avatar
Ding
15-13 (jagrepair.com)
Your full list for the X300 here
JagRepair.com - Jaguar Repair Information Resource
Old Sep 21, 2024 | 09:07 AM
brinny's Avatar
Thanks for the swift reply. Not sure what you mean by tsb? Also nothing on jag repair forum but thanks for the info.
Old Sep 21, 2024 | 09:19 AM
Parker 7's Avatar
Technical service bulletin
Thought I saw some oil pressure references in the past on the forum
separately from the oil pressure there is some stuff on leaking O - rings at the seperate block the oil filter screws into
Will be at dialysis and resurface in a couple of hours on chair
Old Sep 21, 2024 | 09:38 AM
Parker 7's Avatar
LNA5642CA - Jaguar Oil pressure transducer | Jaguar Land Rover Classic Parts
Old Sep 21, 2024 | 09:47 AM
Parker 7's Avatar
oil sender position
Old Sep 21, 2024 | 09:50 AM
brinny's Avatar
Hi, out of stock unfortunately
Old Sep 21, 2024 | 10:10 AM
motorcarman's Avatar
https://www.rockauto.com/en/catalog/...+/+switch,4588
Old Sep 21, 2024 | 11:32 AM
Parker 7's Avatar
Rock Auto has the part listed as ÜRO PARTSJLM20791
So ? is that an even higher version and reference ?
More Information for ÜRO PARTS JLM20791 (rockauto.com)
Old Sep 21, 2024 | 11:36 AM
brinny's Avatar
That's great thanks. Be ni e to find a UK supplier. This should be readily available you'd think.
Old Sep 21, 2024 | 12:49 PM
I sometimes just use the site to get part numbers and brands.
Then you can decide if you can get parts local or AMAZON next day?
Shipping is always a few days or a week with Rock Auto but sometimes you need something RIGHT NOW.
Old Sep 22, 2024 | 04:22 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
The oil pressure switch is in stock at British Parts
https://www.britishparts.co.uk/class...ssure-jlm20791
Also David Manners
https://jagspares.co.uk/oil-pressure...xjs-jlm20791-3
Old Sep 27, 2024 | 10:56 AM
brinny's Avatar
Many thanks all for your help. Got one on order from david manners.
TurboWood
Oct 28, 2023 11:01 PM
Esprit
Mar 4, 2022 10:33 PM
jazzwineman
Jun 1, 2017 10:37 AM
nine7xk8
Aug 15, 2013 04:06 PM
Kiknazz
Nov 15, 2012 08:05 PM
