ole girl needs work
Old Jun 21, 2013 | 11:01 PM
Chris Craddock's Avatar
Default ole girl needs work
Hello all!
I have an old car for a project its a 94 Jaguar xj6
My Father in law gave up on it now its in my hands to either fix it or sell it
I dont want to give up right away
Got two codes
p0122 Throttle Position Sensor/Switch 'A' Circuit Low Input
P0177 Fuel Composition Sensor Circuit Range/Performance
Does anyone know where I can start.
Chris
Old Jun 22, 2013 | 01:55 AM
mikesmith2's Avatar
I would start by clearing the codes then doing a hard reset.
Then see if the codes come back, if they do check the various connections for corrosion and tightness.
Old Jun 22, 2013 | 04:58 AM
sparkenzap's Avatar
Chris:
Just to clarify, what car are we talking about? This is the forum for X-300. That is MY '95 through '97 in the US. Your "facts" don't give a location, so it is somewhat ambiguous since in the UK, MY 94 can refer to an X300 also.
The codes you gave do not have the descriptions you gave FOR THIS CAR.
P122 is just "low TPS value", and P177 is "Adaptive fuel metering trim too rich"
I agree with Mikesmith's advice, but if they return you will probably need to look at replacing the TPS. They are not cheap,($200-$300) but they are available. Since there are no adjustment screws, setup is a bit tricky and is best done with the dealer level software.
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
philwarner
Sep 5, 2015 10:05 AM
