How's it going..
I'm having trouble with my 96 xj6 it's overheating when I turn the AC on.. the temp hand is normally riding right in the middle .. sometime Rises if I'm sitting at a light for a long period Of time or anywhere else .. Does anybody have any theories or solutions..?
Check the engine/climate control heat exchanger fans (RAD FANS).
lots of TSBs for that era fan issues.
I just had a customer that kept loosing the top Rad hose and coolant. She came in and I found both fan fuses melted!!
bob
The fans Are working.. I guess my question would be are they high/low fans. As in are they supposed to kick in at a higher speed when the AC is being ran..?
Originally the lower fan kicked in at a lower temperature (86C) and refrigerant pressure (12 Bar) but the later cars are modded so that it is permanently powered.
The 2nd fan comes on with higher temperatures (100C) or refrigerant pressure (20 Bar).
There was a TSB for earlier cars to be modded to behave in this way (attached).
I had faulty wiring to the lower fan which meant it wasn't behaving properly and the AC was over-pressurizing.
But even when the lower fan wasn't working at all the engine temp was always good - UK temperatures mind.
I think you should have more cooling capacity regardless of AC.
BOTH fans run in SERIES on the low speed and run in PARALLEL on the high speed.
The fans are NOT independent. They both run at the same speed together. (low or high)
