Overheating when AC is turned on
Old Sep 6, 2019 | 03:51 PM
goodgame's Avatar
Default Overheating when AC is turned on
How's it going..
I'm having trouble with my 96 xj6 it's overheating when I turn the AC on.. the temp hand is normally riding right in the middle .. sometime Rises if I'm sitting at a light for a long period Of time or anywhere else .. Does anybody have any theories or solutions..?
Old Sep 6, 2019 | 04:25 PM
motorcarman's Avatar
Check the engine/climate control heat exchanger fans (RAD FANS).
lots of TSBs for that era fan issues.
I just had a customer that kept loosing the top Rad hose and coolant. She came in and I found both fan fuses melted!!
bob
Old Sep 7, 2019 | 02:37 AM
goodgame's Avatar
bob
The fans Are working.. I guess my question would be are they high/low fans. As in are they supposed to kick in at a higher speed when the AC is being ran..?
Old Sep 7, 2019 | 06:02 AM
Lady Penelope's Avatar
The water pump belt may not be turning because of a defective and internally slipping harmonic balancer
The compressor pulley " load " may be triggering this
This involves 2 different engine belts , but they are tied together at the harmonic balencer " drive " pulley
Place 2 white stripes on the balancer and see if they stay together as needed
This staying together can be checked before and after engine run and not necessarily during
https://www.jaguarforums.com/forum/x...lancer-101674/
Old Sep 7, 2019 | 06:54 AM
rod_f's Avatar
Originally the lower fan kicked in at a lower temperature (86C) and refrigerant pressure (12 Bar) but the later cars are modded so that it is permanently powered.
The 2nd fan comes on with higher temperatures (100C) or refrigerant pressure (20 Bar).
There was a TSB for earlier cars to be modded to behave in this way (attached).
I had faulty wiring to the lower fan which meant it wasn't behaving properly and the AC was over-pressurizing.
But even when the lower fan wasn't working at all the engine temp was always good - UK temperatures mind.
I think you should have more cooling capacity regardless of AC.
Old Sep 7, 2019 | 08:04 AM
BOTH fans run in SERIES on the low speed and run in PARALLEL on the high speed.
The fans are NOT independent. They both run at the same speed together. (low or high)
bob
Old Sep 7, 2019 | 10:17 AM
goodgame's Avatar
Ok thank you. I will definitely look check that today.
Old Sep 8, 2019 | 07:35 AM
rod_f's Avatar
I remembered it otherwise but motorcarman is absolutely correct, my error.
Apologies for being misleading.
Old Sep 8, 2019 | 07:37 AM
rod_f's Avatar
Double Post
Old Sep 12, 2019 | 03:20 PM
goodgame's Avatar
bob
Which switch or sensor is the one that triggers the fans to run on high..?
Old Sep 12, 2019 | 03:33 PM
The engine temp and/or the a/c system pressure will determine when the fans 'jump' to high speed.
bob
Old Sep 12, 2019 | 07:57 PM
The 2 position 3 wire coolant temp switch on the aft rear lower portion of the radiator will trigger the left only or the both fans operation
The A / C freon has a 2 wire low pressure switch for the left fan only and a 4 wire high pressure to turn on both fans
There was a TSB to keep the left fan on at all times regardless of coolant temp and freon pressure
Not all cars have been moded
The heart of the fan control is the fan control relay module
This is located under the car just fwd of the left front wheel
To test the fans remove the 3 wire coolant temp connector and jumper the white wire to the black wire with a paper clip and you'll get the left fan
Remove the clip and jumper the other white wire to black wire and you will get both
This is a low current portion of the circuit so no arcing danger and key on but engine not running
To test the A / C switches remove and jumper the 2 wire pressure switch and you will get the left fan only
For both fans jumper the 4 wire connector with the White / Blue wire and any of the 2 Black wires , doesn't matter
The Blue / Black wire is the overpressure switch that shuts the A / C off
The fan control relay modules can get water inside ruining them if mounted upside down
You can shake it and hear the water
For troubleshooting you can carefully remove the right fan motor connector and bring it over to the left fan motor
The White X300 module is not interchangeable with the Black module for the later V8 X308
Ask questions
tford
US Northeast
May 31, 2011 11:03 AM
martinvecchio
XJ40 ( XJ81 )
Nov 3, 2009 09:50 AM
