P1777
Old Oct 13, 2021 | 11:35 PM
jomo's Avatar
Default P1777
I have a p1777 code and the transmission light is illuminated on my dashboard.
I have tried three different TCMs on the car including the one that was on the car when I got the car with no change. So i suspect that the TCM is not the problem.
Doesn't the TCM communicate with the ECM? How would I verify that there is or is not communication between the two modules.
Any other idea or information that you need?
Thanks,
Jomo
Old Oct 13, 2021 | 11:44 PM
scottjh9's Avatar
http://www.jagrepair.com/images/TSB/...d%20Module.pdf Have you read this. I only could copy and paste. Might need a flash using sdd/ids to upgrade software
Old Oct 14, 2021 | 12:22 AM
Parker 7's Avatar
The transmission control module also communicates with the transmission body as there is a speed sensor inside the transmission
The connector is on the left side rear and points aft
Fluids can get on this connector and can be cleaned
You can get to this connector without jacking but there is a trick to removing it using tywraps ,
See post 24 and 25
https://www.jaguarforums.com/forum/x...etting-worse-2
Its the black one
Old Oct 14, 2021 | 10:08 AM
jomo's Avatar
@Parker 7,
Thanks for the reply. The link you attached does not go beyond post number 14 so I can't view post 24 and 25. When you have time can you please supply me with the correct link.
Thanks,
Jomo
Old Oct 14, 2021 | 10:22 AM
jomo's Avatar
How would I go about flashing my TCM?
Old Oct 14, 2021 | 12:28 PM
Parker 7's Avatar
Now I remember how that transmission connector works and how I was confusing it with a Bayonet connector
The term DEUTSCH comes to mind but I can be wrong
The 3 / 120 degree post go into 3 spiral groves n the barrel with the white paint mark
The twist to disengage it is about a 1/2 turn
the trick point is the locking feature so it doesn't migrate and rotate loose in service
If you think of the 3 spirals as streets but in this case the 3 streets have a culdisack at the ends that the post park in , to unseat the post as it rest in the coldisack you have to pull a small dimension down the barrel then twist
This works OK if the connector is not internally corroded , but to make it work once it is you have to obey it's workings
To remove it the barrel has to go straight aft as mounted ( about 1/8 inch ) and only then rotate it
This is where soaking overnight with penetrate helps
__________________
Lady P . is a 1996 4.0 N/A Sovereign 110k miles ( 7/31/17 )
Old Oct 14, 2021 | 01:10 PM
motorcarman's Avatar
Here are some TSBs. (the ones NOBODY reads)
File Type: pdf
Old Oct 15, 2021 | 10:54 AM
scottjh9's Avatar
[QUOTE=jomo;2453321]How would I go about flashing my TCM?[/QUOTE
you need sdd/ids or stand alone ids to flash modules. I am not absolutely sure but your car will use ids. Motorcarman knows for sure. Anyway it needs to be done correctly and with genuine oem setup
Old Oct 15, 2021 | 08:12 PM
xalty's Avatar
nothing on this car can be flashed it’s all plug and play.
ids is just to set dealer options and reset the tps/oxygen sensors
Old Oct 15, 2021 | 09:03 PM
scottjh9's Avatar
excellent knowledge xalty. Should have thought it being a 1995 even before the obd2 mandates it would be different. That is why the tsb says replace with updated tcm and not a flash i assume
Old Oct 16, 2021 | 08:11 AM
You do not need to replace the ECM, just the PROMs. (as per the RECALL T493)
I replaced dozens when the recall was in 'full-swing' during the early 2000s.
File Type: pdf
Old Oct 16, 2021 | 10:59 AM
Parker 7's Avatar
T493 pertains to the engine ECU which is a whole different thing outside of your symptoms in my opinion unless there is a issue of the throttle cable not returning to the closed stop idle position giving him problems in " the mix " of things
Old Oct 16, 2021 | 11:32 AM
jomo's Avatar
I initially had some engine codes on the car and swapped out the ECM with another one I had. The ECM had a sticker on it which I guess meantthat the ECM had the updated PROMs in it. Well that one is back in my car. I have some things to do before taking the car for a drive. I sure hope that fixes my transmission problem.
This forum is awesome!
Jomo
Old Oct 16, 2021 | 12:04 PM
Parker 7's Avatar
A different ECU with your curren installed TPS and EGR have to be a match otherwise the engine regulation can be off
Do not touch the TPS until you have a understanding of it
The transmission speed sensor inside communicates to the transmission ECU which commands the engine ECU to unload the engine when reaching a shift point
This causes problems in the area of idle that is most noticeable both in terms of the speed sensor and the different TPS matching or " orientation " of the engine ECU
Sometimes you get lucky with a match of a replacement ECU and its orientation and the TPS mounting before TPS adjustment
davemac
Dec 13, 2015 06:40 PM
NLXTypeOwner
Nov 21, 2013 05:29 AM
harryc
Apr 24, 2012 01:42 PM
BradMilton
29
Apr 24, 2011 08:59 AM
MRomanik
Sep 12, 2009 10:33 PM
