power steering
Old Aug 16, 2010 | 06:51 AM
madfred's Avatar
Default power steering
hi all doe"s any one know what fluid i need for my 95 x300 power steering as having to renew pump
Old Aug 16, 2010 | 08:17 AM
Doug's Avatar
Ordinary automatic transmission fluid. Dexron is fine. Doesn't have to anything exotic.
Old Aug 16, 2010 | 10:58 AM
madfred's Avatar
Default doug
hi mate, was just wondering dexron 2 or 3 to be honest would it matter
Old Aug 16, 2010 | 12:52 PM
Doug's Avatar
Doesn't matter, IMHO. The power steering system isn't that fussy.
I buy quarts of generic store-brand "universal" ATF from Walmart for use in Jag power steering systems....or any other cars that specify ATF for that purpose.
Old Aug 17, 2010 | 12:29 PM
Drew's Avatar
I use Mobil1 ATF it's like 8 buck and synthetic
Old Nov 27, 2010 | 02:20 AM
Kevin Burnaby's Avatar
Why did you need to change your power steering pump? Did yours start to loose power assist at idle and parking?
My steering rack was leaking so my long term mechanic put in a rebuilt one. The entire system was flushed and done by the book. Now I find the car is very hard to parallel park.
Now he wants to change the power steering pump. The car handles fine and the steering has power assist as long as the engine revs over 900 RPM.
Anyone had any similar experiences?
Old Nov 27, 2010 | 04:30 AM
@Kevin, your old leaky rack, could have put a strain on the pump causing it to over work, or at worst pump air.
Check your tyre pressures, a soft one will cause you problems, but not expensive to fix.
You system is obviously working to a point, because a dead PS system on these cars is like trying to move a building by pushing one handed.
First check that the pump drive belt is good and is not slipping.
Then if all is good here, check your fluid level.
Raise and support the front of the car (axle stands) now turn your wheel from lock to lock several times.
Check fluid level.
Start car, repeat turning wheel as above.
Check level.
Lower car.
Repeat turning wheel as above.
Set wheel straight.
Check fluid level.
At least you will have followed the bleeding procedure, before deciding that it is an expensive pump that needs changing.
If you do in fact need a pump, why not give one of our sponsors a try on a good used one.
You can email, justin.cambra@SpecializedPartsPlanet.com
or,
__________________
Contact Us
(888)908-7575
Ask for our Jaguar Specialist ( Jaguar John or Carl )
British Division
Specialized Parts Planet
- Click here for our eBay Store
Let us know how you get on.
Old Jul 15, 2013 | 06:03 AM
Car-Nut's Avatar
Guys,
Having to change my PSP I dont have an owners manual how much ATF will the replacement pump take….
Old Jul 15, 2013 | 08:24 AM
mikesmith2's Avatar
You don't need a manual, in the cap is a dipstick.
I would think 2 ltrs is plenty as the pot isn't that big.
Bcrary3
Sep 26, 2015 10:36 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
