Power steering issue
Old Jan 28, 2015 | 01:33 PM
gordonreid2041's Avatar
Default Power steering issue
Just replaced power steering pipe from rack to pump on my XJ6 1997. When I touch the steering wheel it goes to full lock on left violently. Any help would be appreciated.
Old Jan 28, 2015 | 01:58 PM
Welcome to the gordonreid2041,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
Old Jan 28, 2015 | 06:02 PM
FrozenApple's Avatar
Might be because of air/lack of fluid inside the lines or the rack, try to turn the steering by hand with cap off and fill fluid to level then start the car.
Old Jan 29, 2015 | 04:13 PM
Hi, seems to have been air after all thankfully. Disconnected pipes from rack and bled them till fluid ran clear which seems to have done the trick. Not road tested yet but fingers crossed
Thanks again
Old Jan 29, 2015 | 04:36 PM
Don B's Avatar
Thanks again
Hi gordonreid2041,
Welcome to the Jaguar Forums!
The easiest way to bleed the steering system (per the Jaguar Workshop Manuals) is to start the engine and turn the steering wheel lock-to-lock, back and forth, several times, until all the air is bled out of the system by the normal function of the hydraulic system. Check the fluid level and top it up if necessary. That has always worked for me.
Cheers,
Don
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
AL NZ
Sep 4, 2015 08:39 PM
