Pressurised fuel tank
Old Jun 11, 2024 | 01:54 PM
Advinnie's Avatar
Default Pressurised fuel tank
Hi all I have a 1997 XJ6. I have noticed lately that every time I take the fuel cap off there is a big release of air that comes out of the fuel tank. Tonight I took the car to the petrol garage after it had been sat for a week and when I undone the fuel cap it shoot up about 6 inch’s and almost took my eye out. Does anyone know what would be causing this ?
cheers all
Old Jun 11, 2024 | 01:56 PM
Vee's Avatar
Vee
Rochester valve failure likely. Either that, or there is a blockage in your fuel tank vent line.
With pressures like what you're talking about, you will want to resolve this before you spring a leak in your fuel tank.
Old Jun 11, 2024 | 02:07 PM
Advinnie's Avatar
that for the reply mate. I will and google what this valve is now
Old Jun 11, 2024 | 04:04 PM
Parker 7's Avatar
There are 2 versions of the EVAP system on the X300 , one with and one without Rochestor valve
Some have plumbed in the valve backwards
There should be a simple blow in tubes test , but probably easier to just replace with fresh part
There is a Delco ( GM ) equivalent # 214552 or 214 - 552
Amazon.com: ACDelco 214-552 GM Original Equipment Vapor Canister Purge Valve : Automotive Amazon.com: ACDelco 214-552 GM Original Equipment Vapor Canister Purge Valve : Automotive
The difference is if you peek under the car without jacking you will have one rectangler box vapor canister on the left just fwd of the rear tire
The other is if you have 2 , one on ech side of the car
See page 60
jagrepair.com/images/Training Guides/801S - 2000.pdf
The second version is electrical that you can check at the ECU connectors
Black 24 and 31 , should not be open or infinite resistance
This electrical valve version may have to do with California emissions or US market as a whole as it's installment is mixed around on production , threw me for a loop and gave me a spot of stumble under my bonnet
Old Jun 11, 2024 | 09:46 PM
Vee's Avatar
Vee
I would just remove it entirely and pipe it straight to the charcoal canister.
I don’t believe the AC Delco part works as well as the original.
Apparently the original can be popped opened and cleaned, supposedly will work like new then?
Old Jun 12, 2024 | 04:28 AM
Advinnie's Avatar
Thanks for the replies everyone l. I will get under the car tonight and have a look. Could this also be linked to why I can only fill the fuel tank to 3/4 from empty? I can fill the tank to 100% full but only if I start with 1/2 a tank if more
Old Jun 12, 2024 | 04:58 AM
Advinnie's Avatar
See page 60
I have the 3.2 xj6 not the 4.0. Will may car still have all the parts in the same location?
Old Jun 12, 2024 | 06:03 AM
Cafcpete's Avatar
On my UK car I think this is the location of the valve.
Old Jun 12, 2024 | 07:03 AM
Advinnie's Avatar
that’s for that mate 👍🏻
Old Jun 24, 2024 | 10:02 PM
44lawrence's Avatar
When I had my 91 XJ-S that fuel tank pressure drove me nuts. Long story short, get second gas cap & drill a 1/16" hole. Never had a woosh after. I know some will say that's a "no no" but so are "95 mph Italian tune ups" etc
alistairolsen
May 18, 2021 06:53 AM
13was13
Oct 28, 2014 04:18 PM
smgdata
Jun 25, 2014 10:57 AM
Calhale
Nov 20, 2012 07:45 AM
Jag_Generation
Apr 29, 2012 12:10 PM
