Recommend a new headliner fabric.
Old Apr 7, 2020 | 02:18 AM
Ed209's Avatar
Default Recommend a new headliner fabric.
I'm tackling the sagging headliner while on lockdown. I'm going to try and get the board out and just replace the fabric itself. Can anyone recommend a good headliner fabric, preferably one that matches the Jag original?
Old Apr 7, 2020 | 03:09 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
There are plenty of re-trimming companies that can supply an exactly matching replacement. An internet search should find them but it depends on your location and if they are still operating in the current covid19 situation.
Old Apr 7, 2020 | 06:52 AM
aholbro1's Avatar
Make sure you get the 1/8" / 3 mm thickness instead of the relatively more popular/available 1/4"...particularly if you are also doing the sunroof panel. With all due respect to V126man, after 20+ years of sunlight exposure, even if you had a couple yards off the very bolt of material used to produce your car back in the 90's, somehow stashed away in a warehouse and preserved for your use now, it is highly unlikely it would match any fabric you are not changing, such as A-pillar posts, overhead console, or, possibly sunroof inner panel. But you can get very close.
Old Apr 7, 2020 | 08:02 AM
Mkii250's Avatar
Have no idea where you are....but here in southwestern Ontario there's a chain of big stores called Len's Mills. They sell primarily fabric off bolts in many colours, styles, materials...including a section of headliner fabrics. They also carry the high-temp adhesive.
Old Apr 7, 2020 | 09:33 AM
Ed209's Avatar
Thanks Guys.
I'm in South London. We're in lockdown so I'm looking to have this delivered really. From what I'm reading there are two headlining colours, grey and beige. I have black leather interior and I'd say my headlining is more of a grey than a beige. Would it be right to call it Nimbus Grey?
Old Apr 7, 2020 | 09:35 AM
Ed209's Avatar
Oh, here we go:
https://www.myrtleltd.com/product/ja...ing-cover-kit/
£77 though with VAT and shipping! Might check for something cheaper.
Old Apr 7, 2020 | 09:41 AM
Ed209's Avatar
Getting there:
https://www.ebay.co.uk/itm/JAGUAR-HE...AAAOSw8Mtdnbfk
Old Apr 7, 2020 | 09:56 AM
Ed209's Avatar
Or I risk it and just get "Grey" for half the price:
https://www.ebay.co.uk/itm/Car-Headl...AAAOSwWtBbk6pR
Anyone bought a cheap "grey" that matched ok?
Old Apr 7, 2020 | 11:19 AM
Ed209's Avatar
Now I'm not so sure, what colour my headlining is, in some lights I'd say grey, but in others oatmeal.
Is there a code on the car somewhere?
If it's any help, it's an XJR in Spruce Green with Charcoal leather.
Old Apr 7, 2020 | 11:21 AM
Cafcpete's Avatar
Not for my Jaguar, but when I needed trim for my Rover I used these people.
https://martrim.co.uk/car-trimming-s...ining-kits.php
Old Apr 7, 2020 | 11:48 AM
Mkii250's Avatar
If you use an other-than-original grey, the visors and several small parts will be a noticeably different shade. I found this out by using a "close match" but non-original fabric in another car.
Old Apr 7, 2020 | 02:43 PM
aholbro1's Avatar
A label in the (front) door jamb. In US Spec cars, it is in the LHS (Driver's) THere will be a 3-char paint code an a 3-char interior trim code.
Old Apr 7, 2020 | 05:07 PM
Ed209's Avatar
I've checked all door jambs and I don't have this label. This is a UK car BTW.
I've got a label under the bonnet that gives "TRIM LEG KL". I think LEG is charcoal leather, but what's the KL about?
Old Apr 8, 2020 | 02:21 AM
SleekJag12's Avatar
A discussion from January where I learned of the two colors of headliner fabric:
Headliner Fabric Color
A "Warm Charcoal" or black leather interior (code LEG) will have a "Nimbus Grey" headliner (code LFJ). Maybe this will help.
Old Apr 8, 2020 | 02:35 AM
Ed209's Avatar
Ah yes, interesting.
It's difficult telling whether it's a grey or an oatmeal; with flash on it looks oatmeal, with flash off grey.
So the PDF would suggest I have Nimbus Grey, since I've an XJR with Charcoal leather. Have I interpreted the chart correctly? Is that enough to go on to be sure I've got Nimbus Grey headlining?
File Type: pdf
Old Apr 8, 2020 | 02:59 AM
SleekJag12's Avatar
Yes... I was editing my above post to include the correct code of LFJ for "Nimbus Grey" fabric. Hard to tell the two apart unless side-by-side I think.
Old Apr 8, 2020 | 03:29 AM
V126man's Avatar
I bought mine from Martrim as a kit including the correct glue for around £80 including delivery.Excellent service. I ordered enough material to retrim everything. The colour match was perfect and I only needed to recover the roof panel. We don't get a lot of sun here so the original had not faded.
https://www.martrim.co.uk/
Old Apr 8, 2020 | 03:33 AM
Ed209's Avatar
Where should I be looking to find this LFJ code?
The code I have on the label is TRIM LEG KL.
Old Apr 8, 2020 | 03:34 AM
Ed209's Avatar
Thanks, yes I've considered them; my problem is knowing what colour headlining I have.
Is it a given that a charcoal leather interior will have Nimbus Grey headliner?
Old Apr 8, 2020 | 08:36 AM
V126man's Avatar
Parts listing shows LEG leather as Warm Charcoal with roof trim in Nimbus Grey.
Copied from the pdf parts listing - see the attached (if not too big to post - not showing in Current Attachments)
Page 8 Trim Chart
Page 10 Breakdown Of Trim Combination Chart
I got Martrim to send samples to confirm the colour match before ordering.
