Removing wishbone tie from differential
Old Nov 21, 2015 | 08:47 PM
greverrr's Avatar
Default Removing wishbone tie from differential
Hi guys and gals,
I am in the process of removing the wishbone tie from a 97 XJR X300 differential. Unlike an X308 where the wishbone tie simply slides onto the tie studs, it appears with the X300 the bushings are bound to the studs somehow. Do I burn the bushings out until the tie slides off the studs or am I approaching this in an obscene brut fashion? Any tip or trick would be appreciated or I give it 15 more mins of burning and then the angle grinder comes out to play. Thanks!
Old Nov 21, 2015 | 09:45 PM
motorcarman's Avatar
They are bound to the lower studs by CORROSION!!!!!!!!!!
They are supposed to slide off just like the X308.
If and When you get them off, you might try some anti-seize compound for the next time.
bob gauff
Old Nov 21, 2015 | 10:32 PM
greverrr's Avatar
Seems about right, the diff is out of a New England car. In that case, my method moving forward with heat and then angle grinders is correct! Thanks as always Bob
BlacXJRcat
22
Sep 26, 2022 08:05 AM
rui
Dec 3, 2015 10:42 PM
Avro RJ
Nov 30, 2015 07:40 AM
Jaguar Forums Editor
Jaguar Press release
Nov 16, 2015 04:58 PM
Avro RJ
Nov 16, 2015 08:19 AM
