rotors and brake pads
Old Feb 23, 2018 | 03:19 PM
xjfourty's Avatar
Default rotors and brake pads
Hello,
so I need new front rotors and break pads.
Any brand/item to suggest me ?
thank you very much
Old Feb 23, 2018 | 05:16 PM
Lady Penelope's Avatar
There are caliper kits to replace the seals and pistons if interested .
Old Feb 24, 2018 | 03:35 AM
AL NZ's Avatar
I don’t know how you drive, but I went with slotted front rotors and red stuff front pads in my XJR because when fast driving on a local windy road, I was getting brake fade after a few miles. I’ve upgraded an earlier non-Jag car I owned similarly and never regretted it - it saved my hide a few times under normal driving conditions in heavy traffic
Old Feb 24, 2018 | 07:25 AM
al_roethlisberger's Avatar
Default OEM and Akebono
I had my OEM rotors turned, and they are still good at least after 50k miles (they may be older, I don't know as I bought the car with 40k miles). The OEM rotors are very heavy and seemingly quite good. So if you still have your OEM rotors, you may want to see if they can be turned. O'reilly auto parts turns them for about $15 each.
After quite a bit of research, I settled on the Akebono Euro ceramic pads. They offer a good balance between good performance, long lasting (again, 50k + miles so far) and almost no dust.
For regular road driving without too much high performance focus, this is a good option.
Old Feb 24, 2018 | 08:53 AM
Doug's Avatar
+1 on Akebono pads. They're great.
As for rotors....
On the several Jags I've owned over the last 20+ years, including the X300/XJR, I've used Bendix, Wagner, Lucas, NAPA, Centric....no complaints or problems with any of them
Old Feb 27, 2018 | 11:42 PM
xjfourty's Avatar
thanks
Old Feb 28, 2018 | 08:08 PM
Don B's Avatar
Hi xjfourty,
You don't mention the year and model of your Jaguar, but over the years, companies that have made original equipment brake pads and rotors for Jaguar include:
Girling
Dunlop
Jurid Werke
Lucas (probably made by Jurid)
Ate
Mintex
Ferodo
Bendix
Brembo
Honeywell (now part of Federal-Mogul)
Textar (X358)
ITT Motion Technologies (current XJ)
You can't go wrong with any of the above, depending on the vintage of your Jag.
For reduced dust, I add my vote for the excellent Akebono ceramics, but Centric and NAPA Adaptive One ceramics are great too, sometimes at lower prices.
For rotors, I really like the coated ones from Zimmerman and Bosch, and I've had no problems with non-coated ones from Brembo, Pagid, Ate, Centric, Wagner and NAPA Gold and NAPA Altrom (typically sourced from an OEM). For normal driving, I recommend non-drilled non-slotted rotors, since those can cause mild brake pedal pulsations and are really unnecessary unless you brake hard frequently and repeatedly like AL NZ!
Cheers,
Don
CLOVERS
16
Jan 28, 2009 03:15 AM
veffremov
Jul 16, 2008 01:06 PM
ken@britishparts.com
May 5, 2008 06:48 PM
rscultho
May 3, 2008 11:23 PM
