In search of IDS DVD118.5 V.5
Old Oct 23, 2019 | 08:49 PM
Larry Louton's Avatar
Default In search of IDS DVD118.5 V.5
I am trying to reset the Fuel trim adaptations on my 1995 Jaguar XJR6 engine as per Technical Bulletin 18-53. My IDS DVD is numbered 118.5 and it does not have the fuel trim set-up as shown on attached document IDS DVD 118.5_V5 as found in another post on this forum. If any one has disc or even a copy of DVD 118.5_V5 for sale, I would like to purchase it. Please see my ad in the Member marketplace.
Larry Louton
Old Oct 24, 2019 | 03:42 AM
b1mcp's Avatar
I can help you with this. Send me a PM with your email address.
Old Oct 24, 2019 | 08:38 AM
Brendan, Did you receive personal message?
Larry Louton
Old Oct 24, 2019 | 08:46 AM
b1mcp's Avatar
Hi Larry. No private messages received. I'll send you one see if that works.
Old Oct 24, 2019 | 07:26 PM
motorcarman's Avatar
You will notice that the vehicle shown is a 1996 XJS with the AJ16.
You might try to enter your vehicle VIN as a 1996 XJ6 R SuperCharged. (not 1995)
Technically the 1996MY was the first required OBDII compliant model year.
Jaguar did make the 1995MY 'sorta' compliant but I had to use PDU on most of the 1995 Jaguars when I worked at the dealer.
Try SAJPX1149TC780764 as a 1996MY XJR and answer the questions on the screen as they come up for vehicle configuration data.
SAJPX1149TC780764 is an actual 1996MY XJR.
Old Oct 25, 2019 | 08:59 AM
Hello Motorman, The picture shown above is from a different post of a different vehicle. What it does show is what I don't have is the reset fuel trim tab??? I tried your suggestion of a later Vin number and there is no change of the missing tab. Have you got a 97 XJR vin #? I even tried a earlier 95 XJR vin I found at junk yard to no avail.
Old Oct 25, 2019 | 11:01 AM
Cafcpete's Avatar
This is my MY97 XJR6
SAJJPALF3BP794533
Old Oct 25, 2019 | 11:24 AM
Thank you Cafcpete, I can see where everybody is going at with the different vin#. maybe it will bring up a different file therefore maybe the tab for the resetting of the fuel trim. Which makes me wonder does any body have the last six of a Vin for a AJ16 XJS? I'll try anything once.
Thank you.
Larry Louton
Old Oct 26, 2019 | 10:13 AM
Default Wish to purchase IDS DVD 118.5 V_5
Brendan,This scan doesn't want to open in page. but seems to be attached below for your review.
Thank you.
Larry Louton
File Type: pdf
File Type: pdf
Old Oct 26, 2019 | 11:21 AM
Cafcpete's Avatar
Just a guess but try unzipping the files?
Old Oct 26, 2019 | 01:16 PM
That is one heck of a idea, Might try it just for the sport of it.
Thank you.
Larry Louton
Old Nov 6, 2019 | 07:42 AM
If and when you find the fuel trim reset tab, Don't do it unless you have a four gas analyzer working at your disposal. You will wish you hadn't like I do.
Thank you.
Larry Louton
Old Nov 6, 2019 | 09:03 AM
Cafcpete's Avatar
Care to elaborate?
markman
Jan 29, 2021 02:42 AM
nazoben
Jul 23, 2014 09:10 AM
xke1963
Oct 13, 2008 11:33 PM
clnilsen
Apr 11, 2008 07:24 PM
reddrawf
Aug 31, 2006 02:39 AM
