Seat control failure
Old Dec 3, 2012 | 08:05 PM
Boeingtravel95's Avatar
Default Seat control failure
Recently had the passenger side seat stop working all together. Took off the controls and tested it on the drivers side. Works fine on that side. What would be the item to fix. The seat is in the most uncomfortable spot and would like to have all electronics in working order.
Old Dec 4, 2012 | 02:21 AM
mikesmith2's Avatar
Check the fuses in the heel boards first.
Old Dec 4, 2012 | 02:39 PM
Check all the fuses. None are blown
Old Dec 4, 2012 | 03:36 PM
Hgc's Avatar
Hgc
Try the seat control module, it's bolted under the seat base in an xk8. Probably the same in your car.
Old Dec 4, 2012 | 03:38 PM
Hgc's Avatar
Hgc
Sorry, just noticed you have a ford.. You should probably ignore my advice!
Old Dec 4, 2012 | 05:18 PM
No I have a 97 xj6 but I think I will buy a used module and that should do the trick hopefully
Old Dec 4, 2012 | 06:37 PM
RJ237's Avatar
First try swapping the modules, no sense in spending money needlessly.
Old Dec 5, 2012 | 11:47 PM
Is it simple to take out. How do u do so?
Old Dec 6, 2012 | 06:34 AM
RJ237's Avatar
I just looked at mine. If the seat is all the way back you probably can't get at the rear screws, otherwise you just need to remove the four torx head screws to take the seat out.
Old Dec 6, 2012 | 08:19 AM
mgb4tim's Avatar
Torx 50, I believe
Old Dec 6, 2012 | 05:25 PM
The seat is all the way back. I guess I'm going to have to fight with it
42Ajd
Dec 30, 2015 09:45 AM
Clamdigger
Sep 12, 2015 03:43 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Dallas XK8
Sep 3, 2015 12:17 PM
