Side mirror
Old Mar 1, 2012 | 11:50 PM
Grssa's Avatar
Default Side mirror
mine side mirror got domaged, two of three nut are broken off.
What will be prcedure to take all mirror with door holder of the doors?
So I can attach mirrot to holder, new screws or gluing.
Any suggesstion please.
Thank you
Old Mar 7, 2012 | 04:52 PM
zej's Avatar
zej
Thank you
You need to remove the triangular plastic trim panel on the front corner of the window to access the torx-screw which holds the mirror on and electrical connections.
In order to do that, the top-part of the door trim must be removed.
Remove the interior door handle surrounds by prising off the little plastic circular bit and undo-ing the screw.
Slide the timber panel towards the front of the car to disengage the two retaining clips, and the whole timber trim should come free, and give you access to two more screws.
There is one more screw to be undone, hidden behind the circular rubber seal that leads to the door vents.
A couple of plastic pop-rivets later, and the top door-trim should be free.
There's a clip somewhere on youtube that shows this whole procedure.
Old Mar 9, 2012 | 11:55 PM
Grssa's Avatar
I was afraid of this, all this work.
Thank you for respond!
kevinl
Oct 31, 2019 06:15 PM
Razor
Aug 28, 2019 08:34 PM
doctordeuce
Sep 12, 2015 08:30 AM
motorhead69
Sep 9, 2015 10:04 AM
