Spark plugs
Old Jul 26, 2018 | 03:33 PM
Stu II's Avatar
Default Spark plugs
I've seen lots of recommendations for spark plugs. My handbook says Champion RC89 PYC for my UK 3.2. Is this the one to go with, or are there better options out there now?
Any help much appreciated.
Old Jul 26, 2018 | 05:20 PM
AL NZ's Avatar
Stick to Champions you won’t go wrong
i think from memory you need RC12YC
Old Jul 27, 2018 | 06:38 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
I have only ever used NGK spark plugs in all of my cars since around 1980 and never had a problem.
I switched to NGKs after issues at different times with poor quality Champion plugs.
I have been running my 3.2 using NGKs for 8 years - I think the code is BCPR6E
Old Jul 27, 2018 | 10:18 AM
Qvhk's Avatar
There were many previous discussions about spark plugs. Here is Jaguar TSB 05-1-07 [EBC8143 is Champion RC12YC] about what plugs to use, which superseded what was stated in the owner's manual. The purists will stick to Champion Plugs, while many others choose to use NGK instead. I had a terrible experience with a Champion plug in one of my cylinders (read this thread), not sure if it was the coil that killed it or the other way round. I am going to try on with a full set of NGK.
Old Jul 27, 2018 | 10:41 AM
jacklynthejag's Avatar
I had tried NGKs and Champions, my car misfired like crazy and did not run properly. I went with the E3.48, since purchase I've had zero problems. Running with new coils and plugs I am getting about 20 MPG (US) in city and 29 highway.
Old Jul 28, 2018 | 06:54 AM
XJRengineer's Avatar
There are compatibility issues between the coils and some makes of spark plugs. I would strongly recommend staying with the original equipment spark plugs. Champion RC9YCC (except North America, normally aspirated engines)
Old Jul 28, 2018 | 07:22 AM
Stu II's Avatar
Thanks everyone. Much appreciated.
Old Aug 1, 2018 | 02:08 AM
Tcasmarcus's Avatar
the ngk bcpr6e works fine on mine. i have never quite understood why the ngk are sold as standard option to the x300 though. they are another height then the champion standard ones, but they do work fine.
basically the champion plugs are a standard size called iso while the ngk plugs are jis size. the difference is only 2,5mm so i guess it doesnt matter much?
arath25
Sep 1, 2014 07:23 AM
GvilleVDP
Jun 6, 2013 08:20 AM
dsetter
Jun 20, 2012 10:55 AM
SteveJacks
Dec 7, 2011 06:50 AM
Jan 15, 2007 06:56 PM
