speedo problem
Old Aug 1, 2018 | 10:48 AM
monty14b's Avatar
Unhappy speedo problem
every thing works as it should on my instrument cluster except my speedometer ….. dead
Old Aug 1, 2018 | 12:04 PM
Lady Penelope's Avatar
The speedo comes off the left rear wheel speed sensor . Remove and clean with caution as they break easily . Do you have a ABS / TC fail light ?
You can do this without jacking the car and spray the 8 or 10 mm bolt and the through boss a couple of days in advance if it doesn't come off easily
Old Aug 2, 2018 | 04:13 AM
countyjag's Avatar
Lady P is right about the source of the signal for the speedo, but if the wheel sensor was the problem, you would definitely have the ABS/TRAC fail light too. So if you dont have the light as well, you need to look elsewhere for the speedo fault. Removal of the instrument binnacle is pretty straightforward, and would enable you to check the two ribbon cable attachments to it at the same time.
Old Aug 2, 2018 | 09:05 AM
motorcarman's Avatar
SPEEDO PROBLEMS??????????????? What could go wrong????
Old Aug 2, 2018 | 10:47 AM
Old Aug 4, 2018 | 12:08 PM
monty14b's Avatar
Angry speedometer fault
I have purchased a working used binnacle, must this have to be programed by a jaguar garage....speed sensor has been checked it's ok
Old Aug 4, 2018 | 12:44 PM
By " binnacle " you mean ?
Old Aug 4, 2018 | 02:14 PM
kamrakram's Avatar
i got a problem with my x type speedo no lights or mileage showing and car doesnt start it feels like it is immobilised can someone help?
Old Aug 5, 2018 | 05:49 AM
monty14b's Avatar
binnacle in Scotland is also called speedometer cluster
Old Aug 5, 2018 | 06:52 AM
There are some instrument cluster fuses and 4 connectors to look at first as you will not carry your mileage over
See page 96
http://www.jagrepair.com/images/Auto.../jagxj1997.pdf
Old Jul 7, 2019 | 06:52 PM
1951sms's Avatar
Did anyone answer your Question on the speedo ?
Old Jul 7, 2019 | 08:32 PM
I did but nobody appreciated the body strap!!!
bob
Kariblay
Jul 30, 2019 06:36 AM
mindrow
Mark V - X 420G
Dec 30, 2017 05:17 AM
Jaguar Mike
XJ40 ( XJ81 )
Dec 7, 2015 10:19 PM
hoff38
Jul 16, 2014 03:57 AM
