SUNROOF issues !!!!!STILL
so what makes 96 XJR sunroof not open all the way ? Just sent over 450.00 at Jag dealer readjusting sunroof - as body shop when it was painted put a replacement in and it worked great except back would pop up after shutting . brought to dealer and the took it out said had to be lined up properly, then i have new issues- went to open it and it didnt open all the way , went to close and it got stuck closed .- left it at dealer
replaced console switch- now doesnt open all the way and i hear creeking ect? HELP IM getting tired of this!! car has been at dealer more than driven in the last month
There is a black module in there with a little pointer and a tiny gear wheel that needs to be set up precisely right(white mark in the little window), otherwise sunroof wont open and close correctly. I found it complete PITA job and must have taken me 6 or 8 attempts and a number of hours to set it up right. They'll also need to clean up the wire driving the whole thing from all the fluff stuck in it(that causes creaks, binding, stripped gears and broken plastics). Hopefully nothing broke yet, otherwise it can be a proper can of worms.
LEAVE THE SLIDING ROOF CLOSED!!!!!!!!!!!!!!!!!!!(it not an essential option)
Not much us forum members can do about you paying for repairs that are not proper.
If you want advise on ways to repair the sliding roof, there are TSBs and JTIS procedures that you can do but relying on incompetent mechanics is frustrating.
The sliding roof was never the most reliable feature but it can be made to operate.
sqenixs
Aug 27, 2012 01:02 PM
