Sunroof update
Old Jan 24, 2013 | 10:05 PM
Boeingtravel95's Avatar
Default Sunroof update
I took it to an independent place that specializes in sunroof repair and they said they can get me a replacement assembly and install it for 890 bucks. But they said they would have to redo the headliner which is 700 bucks....is the headliner repair necessary? Cant they just put it back up. I have pins in the back and they honestly don't bother me enough to spend an additional 700 bucks
Old Jan 24, 2013 | 10:12 PM
Doug's Avatar
Many of us DIY headining replacement for about $50 in materials and a few hours on a Saturday.
When they have the headliner removed for sunroof repair you could take the panel home for DIY replacement of material.
Those taking the car to a trim shop for headlining replacement usually report paying $350-$400.
Not sure why headlining replacement is *required* in this case....might be a good reason, I dunno....but I'm sure you can do better than $700
Old Jan 25, 2013 | 12:13 AM
plums's Avatar
You could always get two separate quotes:
- repair of sunroof with headliner already removed
- redo headliner
Then, have the trim shop remove headliner to do their part, drive over to the sunroof place for their work, drive back and have the headliner put back in.
Old Jan 25, 2013 | 05:29 AM
Where can I get the supplies to redo the headliner? And how do you do it?
Old Jan 25, 2013 | 07:11 AM
plums's Avatar
There are several writeups in the x308 section.
1983turbojaguarxj6
Jan 11, 2025 10:28 PM
JungleJonny
Oct 5, 2015 03:52 PM
aadjei
Sep 25, 2015 03:07 PM
