Sunroof windnoise
Old Nov 8, 2021 | 02:10 PM
JezuzNoChill's Avatar
Default Sunroof windnoise
The sunroof is repaired, drain channels replaced, SLCM calibrated and in the closed position it's positioned perfectly flush with the body. Is there anything I can do to reduce the wind noise? It's especially noticeable above 120km/h or over 75mph.
Old Dec 26, 2021 | 03:29 PM
cdma's Avatar
Anyone?
Old Dec 27, 2021 | 02:58 AM
countyjag's Avatar
New seal? They are expensive, and apparently difficult to fit, but it would seem logical. Or drive below 75!
Old Dec 27, 2021 | 09:21 AM
cdma's Avatar
Drive below 75......yea right. Don't know if my car will. She just wants to go. The seal? Don't even want to think about taking that headliner out. I guess I will deal with it.
Old Dec 29, 2021 | 03:43 AM
countyjag's Avatar
The seal I was referring to is on the sunroof panel. Roof lining doesnt need to be touched. Maybe try a little bit of grease or silicone on the rubber of the seal to see if it makes a difference?
Old Nov 28, 2022 | 10:18 AM
cdma's Avatar
Does anyone have the procedure to pull the panel out? I need to get the seal replaced, The New Mexico sun has totally trashed it. I will find the seal if I can but the panel I thought the headline had to come out. And does anyone have a JD200 Crimping tool for rent?
Old Nov 28, 2022 | 11:24 AM
Parker 7's Avatar
There is a TSB on installing the seal , you may have to fabricate the tool
This coming from someone who has mot replaced their seal
See page 8 illustration 11
jaguar Service Tool 501-023
13-39 (jagrepair.com)
A generic version of the crimping tool may be looked at with a body shop visit
Old Nov 29, 2022 | 10:42 AM
cdma's Avatar
Well got lucky. So I had another sunroof that I took off my parts car. I pulled off the seal and put it on my current sunroof. Went on like butter. Put some WD40 inside the seal, heat the seal a little, and used a rubber mallet to push the seal on. Now need a second hand to help align the roof, and I will be done. If the seal is used, you don't need the tool. Just a little patience.
Old Dec 25, 2022 | 02:59 PM
cdma's Avatar
Does anyone have a JD200 crimping tool? I tried JCNA tool lending but cant get anyone to respond. I saw that someone made one and that it might work
Grossy
E type ( XK-E )
Aug 26, 2021 01:02 AM
Versatile
May 27, 2014 08:26 PM
JoeIron
Nov 22, 2012 02:18 AM
josh_77073
May 24, 2012 08:15 AM
fantastic
Aug 14, 2010 11:55 AM
