supercharging a x300 3.2
Old Feb 24, 2018 | 05:06 PM
xj-c4.2's Avatar
Default supercharging a x300 3.2
Giving this some thought. Has anyone done it?? So my theory is transplanting a supercharger and manifold off an XJR onto my X300 sport 3.2. The obvious would be bigger injectors and ecu re-map. Do we think this is o bolt on option onto the 3.2 aj16
Old Feb 24, 2018 | 05:30 PM
Lady Penelope's Avatar
MAF meter will extend into the saturation curve on the present one , Headbolts , Valves and Valve seats , Cam ? , Stronger Crank if not the same metallurgy of the different S/C crank , optimized compression ratio or was that to limit the mechanical power limit ?
Old Feb 24, 2018 | 07:21 PM
AL NZ's Avatar
Aston Martin did it with the DB7 didn’t they?
Old Feb 24, 2018 | 07:24 PM
al_roethlisberger's Avatar
I think the pistons are different too.
The compression ratio on the SC cars is lower as I recall as well, so just bolting on the SC parts would cause severe detonation.
Old Feb 25, 2018 | 05:20 AM
xj-c4.2's Avatar
Mmmmm. some good points. But in my experience as a mechanic and a shop owner is lowering CP ratio is a good idea but all the other engine refinements are not really required if you keep within a reasonable boost range. I have done many turbo installments to standard engines that hold together well. A jaguar engine is well designed and built I would be shocked if it could not handle some mild boost.
Old Feb 25, 2018 | 05:22 AM
xj-c4.2's Avatar
Correct......
Old Mar 4, 2018 | 02:03 AM
XJRengineer's Avatar
As well as all of the other issues suggested above, the block of a 3.2L engine doesn't have the bosses machined to bolt on the supercharger mounting bracket. Fitting a complete XJR6 engine, harness, ECU, MAF and in-tank fuel pump assembly and control relay would be a better option. This is especially true if the donor car has a manual transmission.
Old Mar 4, 2018 | 02:00 PM
Robman25's Avatar
If I remember correct the block was designed with the thought of producing a diesel variant so the bottom end would hold up. Agreed with the idea of keeping the boost levels low due to the CR.
Also I think there is about 20% capacity left in the ECU fueling map?
Old Mar 5, 2018 | 02:55 AM
AnttiM's Avatar
About the sc fixing bosses; I would presume the block raw casting is the same across different versions of the engine? so the bosses are in the casting "just" need to be tapped and threaded?
on internals :
3.2 crank is casted, 4.0 and 4.0SC are forged (and the same IIRC)
3.2 and 4.0 cam has the same part number so they should be the same
4.0 and 4.0SC cams are same profile and with different timing (as there is adjustable pulleys this should not be a problem) at least I _think_ this is the case
3,2 and 4,0 valves (at least intake) are with same part number
4.0 SC has different part number but what is the difference that I do not know
4.0 and 4.0 sc have forged rods (again IIRC) 3.2 no clue
Old Mar 7, 2018 | 02:47 PM
Yes, the cast bosses are present on the blocks of naturally aspirated engine. They just aren't machined.
I'm not sure what is meant by the statement about "20% capacity left in the fuelling map". Supercharging a naturally aspirated engine should result in a an airflow increase greater than 20%, so whatever "capacity" is being referring to, would be exhausted.
Old Mar 7, 2018 | 04:32 PM
Lower flow rate NA injectors Vs. the higher SC injectors from my understanding the ECU will adjust the pulsewidth to keep your fuel trim at 0.0
Old Mar 9, 2018 | 12:33 PM
The fuel injectors fitted to the supercharged engine are of a much higher flow rate than those fitted to the naturally aspirated engines.
Old Mar 9, 2018 | 01:11 PM
Jagboi64's Avatar
deleted
Old Mar 12, 2018 | 03:18 AM
Qvhk's Avatar
I would imagine that supercharging is to gain additional power but how much more power can this conversion produce, and, considering the costs in terms of time, labour and parts, would all such efforts be worthwhile beyond proving that such a project is doable? Saw some discussions entitled as close to a DB7...(aka the X300 XJR project) in the XJ40 Forum with similar thoughts about supercharging a 3.2 engine.
I would be more tempted to see someone replicating or surpassing Dr Jag's efforts in achieving 430kw power and 700 Nm torque in an XJR. See previous discussion here where Greg Parsons has a great write-up about his Project XJR-6 "from the wrecking yard to the race track".
300bhp/ton
Dec 27, 2011 12:49 AM
handyboy472
May 17, 2011 10:35 PM
Mafioso
19
May 29, 2010 12:49 AM
Iguana
Sep 7, 2008 07:58 PM
1badjag
Aug 7, 2007 12:39 AM
