Tail light issue
Old Oct 9, 2015 | 09:52 AM
SD96XJ6L's Avatar
Default Tail light issue
My dash light for a tail light bulb being out flickers when I drive and goes on when I apply the brake pedal. The bulb in the holder is good. This is the bulb setup on my passenger side. When I turn on the right (passenger) side turn signal the dash light for a bulb outage also flickers. How can I fix this? Is it a ground issue?
Old Oct 9, 2015 | 10:30 AM
Brutal's Avatar
Ground, module or just crappy auto parts store bulbs
Old Oct 9, 2015 | 04:28 PM
Tipptone's Avatar
Successful lights and a successful divorce both depend on good grounds!
Old Oct 11, 2015 | 04:07 PM
littlelic69's Avatar
I understand that not all lamps are comparable! I suggest you swap them around and see if it makes any difference.
Old Oct 12, 2015 | 04:18 PM
SD96XJ6L's Avatar
I am quite sure it's a ground. Is there a diagram out there for the various ground points so I can check?
Old Oct 12, 2015 | 09:02 PM
sparkenzap's Avatar
I suspect you have blown the formerly working stop light circuit by overloading it. Each stop lamp is on a separate circuit so that "BULB OUT"can be determined. It is a known defect in the SCLM, (Security and Locking Module) to short an output device called a HSSSS (High Side Solid State Switch). You can replace the SCLM without reteaching the keys, but the key fob is married to the module. Make sure your replacement SCLM has the same fob frequency and yiou can marry it without too much drama- see archives.
Old Nov 30, 2015 | 09:05 AM
SD96XJ6L's Avatar
I finally figured this out. My 5 AMP parking light fuse on the passenger side was blowing out. I found a bad coil back boot (cylinder 2), replaced the boot, fuse and what do you know. The lights all work now.
crodftype
Feb 23, 2016 01:06 AM
Vtjaguarlover
Dec 6, 2015 04:09 PM
bb_sam
Nov 18, 2015 03:48 PM
tommyzr
Oct 26, 2015 07:41 PM
WhiteJag
Oct 10, 2015 08:41 PM
