is there anywehere new seatbelts are available?
As the title says.
I have my X300 with oatmeal interior and the seatbelts are as one would expect quite dirty and showing some signs of fraying in parts.
I have cleaned these before and will clean these again, (using a pressure washer is fantastic) however was wondering if anyone knew of anywhere one could get some new (likely aftermarket) seatbelts that would fit.
I can only assume that at some point with driving these cars more is that the seatbelt will deteriorate more and end up quite frayed.
You will of course not be able to obtain new OEM belts unless NOS, however if you google HEMCO seatbelts you should have success. They are in Victoria and have a large colour range available.
John Herbert
1996 XJR
John Herbert
1996 XJR
