Thottle Spring
Old Mar 4, 2024 | 03:54 PM
cdma's Avatar
Default Thottle Spring
Has anyone seen this before or is this one off? None of the other XJ6 had this.
Old Mar 4, 2024 | 04:00 PM
Parker 7's Avatar
That is a work around instead of replacing the spring inside the throttle butterfly shaft tower
The original internal spring has been superseded by a stronger internal spring by a TSB
This ensures the TPS comes back to idle stop for proper idle and not be high
Does the cruise control work as the linkage looks wonky ?
Old Mar 4, 2024 | 09:54 PM
cdma's Avatar
Took off the fuel rail to get the injectors rebuilt. But it does work
Old Mar 5, 2024 | 09:23 AM
motorcarman's Avatar
I did that on a few cars while I was at the dealer when the replacement spring was back ordered.(my own cure)
Jaguar issued a TSB for intermittent high idle. (stiffer spring)
The spring setup (shown) is for the AJ6 throttle.
It is easily adapted to the AJ16.
Old Mar 5, 2024 | 01:24 PM
cdma's Avatar
Is there anyway to take this apart? I have a spring that’s broken on the upper part.
Old Mar 5, 2024 | 03:42 PM
Parker 7's Avatar
See page 11 , Issue # 3
05-1-26am5 1995 MYRecall R493.pdf (jagrepair.com)
You will probably have to buy the while TB assembly.
To know if you have the upgrade spring you can compare spring thickness with a micrometer
To know the donor car has be done there will be a sticker on the radiator area , if they followed instructions completely
You can always replace the existing spring with a stronger one if you have a present idle issue
Spring thickness is not the only variable for the spring strength
Old Mar 5, 2024 | 06:27 PM
cdma's Avatar
I guess it does not come off. Anyone have a top of a throttle body they want to sell? My pick and pull does not have any xj6
Old Mar 5, 2024 | 06:34 PM
Parker 7's Avatar
There was someone with pics and instructions as he removed and reclocked / repositioned tighter the original shaft spring
I won't be back for a couple of hours and find it
Old Mar 5, 2024 | 07:11 PM
Parker 7's Avatar
Ding
Old Mar 5, 2024 | 07:23 PM
Parker 7's Avatar
And more
Thanks Motorcarman ( Bob )
No-Cost Solution to Sticky Throttle Return Spring; H/T to Motorcarman! - Jaguar Forums - Jaguar Enthusiasts Forum
Old Mar 5, 2024 | 07:24 PM
Parker 7's Avatar
Cat on keyboard
cdma's Avatar
It is the upper spring that is broken. I need to figure out how to take the “top hat” off. But even if I do I will need to find a spring which I will have to find another complete top hat anyways. That is why I think I just need another one
Old Mar 10, 2024 | 04:56 PM
cdma's Avatar
Anyone have one that they could part with
No Quarter
Apr 21, 2022 03:40 AM
Vonnslingo
Jan 16, 2022 07:52 PM
adenshillito
Apr 16, 2021 10:01 AM
Jimmysea
Nov 1, 2014 03:06 PM
monqc
Feb 1, 2013 04:58 PM
