Throttle Response On Startup
Old Jul 18, 2016 | 07:58 PM
CBSmith's Avatar
Cool Throttle Response On Startup
Just recently, an issue with the accelerator has come up after start-up.
It will take 2 to 3 minutes before I get any pedal response after ignition even when the trans is placed into gear.
My first guess is that the ECM is taking a bit to run its checks.
Has anyone ever run across this issue with the '97 VDP XJ6?
Old Jul 21, 2016 | 11:30 AM
mhamilton's Avatar
A moderator should probably move this into the X308 section.
Old Jul 21, 2016 | 12:45 PM
garethashenden's Avatar
X300
Old Jul 21, 2016 | 01:13 PM
CBSmith's Avatar
Question Throttle Respnse On Startup
Why?
Old Jul 21, 2016 | 02:05 PM
Don B's Avatar
Hi CBSmith,
I have moved your thread from the forum for the X350 to the forum for the X300, which is the Jaguar factory project code for your 1997 XJ6. Here you will find knowledgeable owners of similar cars.
Regarding your symptoms, the accelerator pedal is directly connected to the Throttle Body (TB) by a standard cable, so it seems very odd that you would have no change in engine response when depressing the pedal. The first possibility that comes to mind is a problem with the Throttle Position Sensor (TPS), a potentiometer attached to the butterfly valve shaft in the TB. As the valve moves, the voltage returned by the TPS varies, and from this signal the ECM determines the position of the valve and its rate of change in opening or closing.
A few questions come to mind:
1. Does the accelerator pedal feel stiff and difficult to move when you're experiencing the problem?
2. Have you scanned the car for any stored OBDII fault codes?
3. When you start the engine, is it settling into a normal idle quickly, or is the idle speed high?
Hopefully others will have some helpful ideas.
Cheers,
Don
Old Jul 21, 2016 | 02:34 PM
motorcarman's Avatar
Breather Mod has been NLA for a long time but clean the throttle!!!!!!!!!!!
bob
Old Jul 21, 2016 | 04:45 PM
Don B's Avatar
... clean the throttle!!!!!!!!!!!
Bingo, Bob. Looks like you nailed another one!
Thanks,
Don
Old Jul 21, 2016 | 08:51 PM
al_roethlisberger's Avatar
Thanks,
Don
I have the same intermittent issue, and as described is most common in the cold or after the car has sat for a while.
I've got to clean my TB this weekend.
Old Jul 22, 2016 | 02:51 PM
CBSmith's Avatar
Thanks everyone...I will clean the TB this weekend and get back with the results.
sqenixs
May 1, 2016 09:50 PM
John Callander
Apr 28, 2016 10:17 PM
andy15
Apr 25, 2016 11:12 AM
nothing4u
Apr 23, 2016 11:50 AM
Salu498
Apr 23, 2016 03:13 AM
