Which is the transmission cooler line is FROM the transmission?
Old Jun 7, 2018 | 05:04 PM
al_roethlisberger's Avatar
Question Which is the transmission cooler line is FROM the transmission?
I plan to replace the transmission fluid this weekend or next, and instead of just draining from the pan or sucking it out of the dipstick tube, my plan was to pump it out via the cooler line that feeds from the transmission to the radiator.
Trick is, I'm not sure which line is the supply or return. I could pull either to see, or just let the engine/transmission get hot, but I'd rather avoid both.
So any quick feedback on which top or bottom line is the radiator supply line from the transmission is much appreciated.
Old Jun 7, 2018 | 05:26 PM
Lady Penelope's Avatar
http://shop.ukrtrans.biz/wp-content/...logs/4L80E.pdf
See item 4 and 5 :
https://www.jaguarclassicparts.com/u...e-supercharged
Old Jun 7, 2018 | 06:22 PM
So it looks like it is the "top" line fitting on the radiator.
Old Jun 7, 2018 | 06:46 PM
Old Jun 7, 2018 | 07:26 PM
Someone with hands on would better answer your question as I don't trust technical writers and the names input and output can be crossed . Generally the transmission cooler run across the bottom of the radiator
Old Jun 7, 2018 | 09:02 PM
John Herbert's Avatar
Having previously fitted a supplementary transmission cooler to my Jag I can reliably advise that the input from the transmission goes to the fitting at the left side BOTTOM & the return to the transmission comes from the left side TOP fitting. Item 5 on the parts diagram is correctly stated as "Oil cooler output pipe". Cooler is in the left side radiator tank & flow is from bottom to top.
John Herbert
(1996 Jaguar XJR)
Old Jun 13, 2018 | 11:51 AM
countyjag's Avatar
I would concur with John Herbert. You would want the hot liquid to enter at the bottom and exit at the top of the cooler, which sits vertically at the LHS of the radiator.
Old Jun 13, 2018 | 11:55 AM
countyjag's Avatar
Ps Be very very careful loosening the pipes from the side of the radiator. The easiest thing in the world is to snap the pipe off from the body of the cooler which is inside the plastic end cap of the radiator, which will spoil your entire day, and likely the next few too!
Old Jun 13, 2018 | 12:45 PM
Jagboi64's Avatar
Radiators are NLA too, and different from the NA version. I've not seen an aftermarket radiator either.
mirisisa
Dec 18, 2019 09:13 AM
Lagonia
Aug 14, 2017 09:22 PM
JagCrank
May 12, 2013 09:27 PM
scrimshank
Aug 24, 2012 08:41 AM
bcave
Nov 17, 2010 12:09 PM
