Unusual instrument lighting problem: X300
Old Jan 31, 2021 | 09:08 PM
Alan E L's Avatar
Default Unusual instrument lighting problem: X300
Hi all,
My wife’s high mileage but immaculate 1997 3.2 X300 has a very unusual electrical problem. When the car is parked and the lights off, with or without the key in the ignition, the instrument lights remain illuminated. We keep the instrument lights turned down to minimise battery drain and as the car is in regular use it is not a great problem but I would like to fix it. I have no idea where to start.
Any suggestions greatly appreciated
regards
Al
Old Jan 31, 2021 | 11:55 PM
watto700's Avatar
G'day Alan,
Turn the intrument light dimmer control to it's brightest setting then further turn it until it clicks and that should sort out your problem.
If you select any dimmed setting while driving then for some weird reason, that only jaguar know, when you turn the car off the instrument lights will remain illuminated at the previous dimmed setting. At least that is how it works in my car
Cheers,
Jeff.
Old Feb 1, 2021 | 02:55 AM
Alan E L's Avatar
Thank you Jeff for your prompt answer.
I will certainly try out your suggestion
regards
al
Old Feb 6, 2021 | 02:54 AM
Alan E L's Avatar
Hi Jeff,
Thank you, you were absolutely correct. Problem solved.
Not sure what the idea is with it but there off now.
Kimd regards
al
EZDriver
Nov 26, 2020 08:17 PM
jookul
Aug 1, 2019 03:11 PM
dsd
Oct 18, 2016 08:56 AM
johnny9759
Aug 14, 2016 10:41 AM
