Warm rear wheels
Old Jun 15, 2019 | 12:46 PM
Stu Jags's Avatar
Default Warm rear wheels
I took my x300 for its first motorway run today. Only 30 miles at 70mph. Noticed rear wheels were warmer than fronts. Is this normal? Does any of you guys need an excuse to go for a drive out and check your wheel temps before I start stripping callipers etc for no reason. Thank you in advance
Old Jun 15, 2019 | 03:29 PM
AL NZ's Avatar
tricky one. perhaps, since you are in Wales, find a good long hill and run up it then coast to a stop with minimal braking, and see what they're like.
this was how I used to check my (horrible) Austin 1100 rear brakes were not over-adjusted
the only sources of heat I can think of are brakes, in which case the rotors will be hot, or worn wheel bearings which would be noisy.
plenty of oil in the diff? - again, that'd be noisy of running dry..
Old Jun 15, 2019 | 04:19 PM
Steve M's Avatar
How did you notice that the rear wheels were warmer than the front?
Why did you check?
Was there a noise?
Was it the wheels or the tyres, or both?
How did you check the temperatures; back of the hand or calibrated thermometer? (or old style, pee on them and check the amount of steam generated).
You say it was the first motorway run; since you bought it or has it been in a showroom all of its life.
More info! It sound interesting.
Old Jun 15, 2019 | 04:35 PM
Stu Jags's Avatar
I bought her to do charity banger rally to Gibraltar this September and Have gradually been nursing back to life. Have replaced wheel bearings, stripped and cooper greased breaks, changed all oils, greased UJ’s. I fixed cruise control and repaired ABS Fault. After this I took her for first motorway run and noticed both back wheels were warmer to touch than fronts. Only warmer, back of hand warm. I could just reach calliper through gaps in wheel and that felt cold.
Front wheels where cold, are rears normally warmer than fronts.
we are going to be doing around 800 miles per day for four days in 25 - 30 degrees so don’t want anything generating more heat than necessary.
Old Jun 16, 2019 | 02:24 AM
Handbrake adjustment, or handbrake dragging very slightly.
Old Jun 16, 2019 | 08:57 AM
Stu Jags's Avatar
Been out for 5 mile drive, not much breaking and rear disks just about too hot to touch. I did jack car up, put in neutral and spun back wheel. You can just hear what I think are pads rubbing on disk. If I keep using will they wear down a bit and stop rubbing? I have as them all apart and copper greased everything so nothing should be stuck ?
Old Jun 16, 2019 | 01:02 PM
AL NZ's Avatar
it could be the rear hub park brake shoes, not necessarily the discs/pads, but I'm no expert..
Old Jun 17, 2019 | 02:01 AM
Stu Jags's Avatar
So after 15 miles drive to work, no hard breaking, I would say driving gently, rear disks at 50 degrees fronts at 20 degrees. Is this normal?
Old Jun 17, 2019 | 05:02 AM
I would not think so.
BUT
The front do get dedicated air flow, the rears no, BUT, the rears do 30% of the braking, so air flow is not critical.
I still think park brake shoes need backing off a tad.
rads
Jun 25, 2016 05:31 PM
sheppy
Dec 22, 2014 08:03 PM
jaguars4r
Aug 8, 2012 10:40 PM
jag79
Mar 19, 2012 10:40 AM
poisonpill
May 24, 2010 03:57 PM
