Warning "Cheep" location.
Old Sep 17, 2025 | 03:50 AM
Chestergolfer's Avatar
Default Warning "Cheep" location.
I have a 1996 X330 and its battery keeps discharging. I have bought and installed a new battery, but the problem has not gone away! i read in the Jaguar Enthusiasts magazine that there is a cheep device that has its own small battery. After all its 29 years it is probably defunct but will keep demanding power to recharge it ! This discharges the main battery after some time. These are my symptoms! So my question is , Where is this piece of kit located and how do I get at it? AlecG.
Old Sep 17, 2025 | 03:53 AM
Default cheep
I am a long standing member, not as stated above, but cannot access my old acount for some reason, so have re-registered. AlecG.
Old Sep 17, 2025 | 07:47 AM
Ya Tigor's Avatar
By "cheep" you mean a security system sounder located near the right-side headlight? You can see its sticker easily looking under the plastic cover around the washer tank spout. If it said "intelligent sounder" than there is a backup battery there.
Old Sep 17, 2025 | 07:59 AM
Alexander Gurney's Avatar
That is the one! I will dive under the car when the rain stops! Thank you. Do you know if there is a replacement battery? AlecG. I have checked it and yes it does show “Intelligent Sounder” I guess that it could be removed or disconnected to see if that solves the problem.
Old Sep 17, 2025 | 11:32 AM
Ya Tigor's Avatar
Looking on some info it is not intended to be serviceable as it is filled with the resin and despite it might be cut open to access the batteries it looks like the common fail on this device is a battery leak damage to the electronic board.
https://www.jaguarforums.com/forum/x...ounder-149781/
Old Sep 17, 2025 | 03:00 PM
Parker 7's Avatar
The device has a battery charger for the batteries of some rechargeable type inside potted with a resin compound
The batteries inside can't last forever and has eluded me to the relationship of your stated main car battery drain and its relationship to the SLCM in powering it as a backup , can it just simply be unplugged ?
The potting compound is very tough to remove from trying in the past
Old Sep 18, 2025 | 12:45 PM
Default “Cheep”Sounder
I have now removed the unit and everything locks and unlocks as it should. The headlamps illuminate on pressing the key fob twice, so I hope the battery drain has gone. I have now opened up the unit and as predicted above, one battery was leaking. Unfortunately, the connecting tags between batteries and printed circuit board have separated at the board. I have ordered a new battery pack from Amazon. It is too big to fit in the old unit but I am certain it can be made to work. He says with unbounded optimism! AlecG.
Old Sep 18, 2025 | 09:03 PM
Ya Tigor's Avatar
Dunno if it's significant for you but if battery fix won't work you might just replace the intelligent with a passive sounder LNA2620BA. Lots of them available used.
Old Sep 19, 2025 | 03:21 AM
Jaguar/Land Rover say that the AA version was replaced with the AB version but neither are available new. The concern I have with a used one is how long will it last before it too fails? When did the AB version come into service and when did it cease to be fitted? My AA version is 29 years old! AlecG.
Old Sep 19, 2025 | 11:42 AM
Parker 7's Avatar
Aside from the security sounder unit causing main car battery drain , you get into the area of termed parasitic main battery drain that has been experienced by many and there are solutions
On ignition key removal the ignition in / out linier switch makes between pin 4 and pin 5 ( car frame ground ) that starts a security system sequence of locking things up as you walk away from car
If items fail ( seats and steering column included ) to be seen by sensors / SLCM as you are exiting the car the SLCM will not " go to sleep " as a very low current draw on the main car battery , this sleep is on the level of around 40 milliamperes with trunk closed ( thanks Motorcarman ) so meter observations consideration
See how your solution works out and then maybe have to shift your observations to the car exiting car's behavior
Old Sep 19, 2025 | 11:53 AM
Default Cheep
Thanks for the info on current “leakage” I do have a few other issues. The main one is the steering column reach control, which is broken and I cannot remove one of the broken pieces. I guess this may have an effect on the shut down process? AlecG.
Old Sep 19, 2025 | 03:29 PM
Parker 7's Avatar
Sent something but crashed WiFi , let me try again
Getting closer on defining issue
Old Sep 19, 2025 | 03:33 PM
Default Cheeps
keep trying!!!
Old Sep 19, 2025 | 03:35 PM
Parker 7's Avatar
You can remove both steering and seat from having to move to the car exiting position by turning the large rotary switch on the cars left steering column from auto to off , this removes them from the " go to sleep " need to be at agreements
There are some solutions in that area if need be but for now it does isolate if an issue and no more dead battery
This turning off would have to be done before ignition switch key removal in the sequence of things
Old Sep 20, 2025 | 09:55 AM
Default Cheep
I do have the rotary switch turned off and the seat and steering wheel stay still. However, the driver’s door mirror still repositions.
Old Sep 20, 2025 | 11:19 AM
Parker 7's Avatar
As long as the seat and steering column wheel are not in the exiting the car sequence and not causing main car battery drain
Driver door mirror ...........as long as you don't observe battery drain
Observe no battery drain and we'll come back to being able to have the convenience of auto seat and steering on ignition key withdraw
dibbyandco
Nov 16, 2023 04:43 AM
Holein1
Oct 9, 2023 03:53 PM
jagxkrtoofast
Dec 9, 2022 12:56 PM
fredpribyl
Nov 13, 2020 01:04 AM
domino_z
Nov 18, 2016 05:01 AM
