Water pump gasket
Old Jan 24, 2014 | 01:40 PM
x300drew's Avatar
Default Water pump gasket
Hi all,
I've a question I'm hoping someone can help with. I need to replace the water pump on my 3.2 X300 and was wondering if the gasket needs sealant or should it be fitted dry?
Thanks for taking the time to read this and would appreciate some advice.
Old Jan 24, 2014 | 02:42 PM
RJ237's Avatar
It should be fitted dry.
Old Jan 24, 2014 | 05:42 PM
Doug's Avatar
I always use Permatex #2 on water pump gaskets.
<shrug>
Old Jan 25, 2014 | 01:23 AM
drmike's Avatar
<shrug>
Both sides or just one? I assume that you wouldn't expect to replace the pump more than once so both sides is fine otherwise it's a PITA when the gasket tears where you take the pump off, anyway that's been my experience.
Mike
Old Jan 25, 2014 | 06:48 AM
Doug's Avatar
Both sides.
Old Jan 26, 2014 | 06:18 AM
x300drew's Avatar
Thanks for the info, will be sure to use gasket sealant
silkcat
Jan 18, 2025 04:29 AM
Wahooesprit
Dec 23, 2019 02:01 PM
picard
Oct 12, 2015 11:56 AM
Jaiello21
Sep 14, 2015 09:42 PM
chatmanx
Sep 11, 2015 07:17 PM
