What did you do to your X300 today?
Old Feb 27, 2020 | 01:40 PM
  #801
mrkawasaki's Avatar
Had the tracking done today - took over 2 hours.
Old Mar 1, 2020 | 12:27 PM
  #802
Nobeel Masri's Avatar
I topped up the R134A in the AC system and it is holding around 35psi.
The AC died a few months back and I have been looking into the cause this week. The pressure was low, so after topping up I was relieved to see the AC clutch engaging and am now getting cold air in the cabin again.
I am aware that I may have a leak and will be monitoring it over the next few days to see if the pressure drops.
This was the first time I had problems with the AC in my 2.5 years with the car and I suspect there is a leak somewhere.
Old Mar 1, 2020 | 03:15 PM
  #803
Steve M's Avatar
Looked at it and thought; what on earth possessed me to buy it in the first place?
Mad.
Old Mar 2, 2020 | 11:35 PM
  #804
Qvhk's Avatar
Mad.
You are not alone. Every now and then strangers passing by my car stop and look at the licence details to find out how old is the car, thinking that such car must be something from the 80's.... When they find the car even has a stick, the thoughts push the manufacturing year further back.
Old Mar 3, 2020 | 02:19 AM
  #805
SleekJag12's Avatar
Mad.
Buying with emotion rather than just sensibility. Who can deny the attraction. It's like looking at a sexy woman. Except not socially unacceptable!
This is the best looking Jaguar XJ ever made. I can't stop staring at it. It had me at hello.
Old Mar 7, 2020 | 11:10 AM
  #806
Have been getting the intermittent P0411 code and after around 6 months I decided to set out to fix it.
All the components seem to be in good condition, and I am getting air flowing from the Secondary Air Pump, although it did feel a little weak at the pump.
I decided to swap out the Check Valve as this was the cheapest part option, The new one was had a lot more resistance when blowing through it than the old one
This didn't solve the pending codes, so have now ordered a used Secondary Air Pump which should arrive next week.
Fingers crossed the replacement pump does the trick. TBC
Old Mar 7, 2020 | 12:51 PM
  #807
Steve M's Avatar
Sprayed some underseal on it; on the underside obviously, don't hate it that much.
And a bit on my face too.
And my shoe.
Old Mar 7, 2020 | 08:50 PM
  #808
PunkLegacy's Avatar
I started it up and listened to the radio 😂
I'm having a slight parasitic draw on my battery when the cars running but I'm pretty sure it's just because my battery is from 2013 I found out.
Old Mar 19, 2020 | 03:38 AM
  #809
MikeyB10's Avatar
Default Rear Brake pads
I replaced the rear Brake pads today, after finally purchasing the correct set. I am amazed that Jaguar brakes don't have any low pad ward mechanisms be it mechanical or electrical.
I guess jaguar just assume we are all pedantic fastidious, owners and keep an eye on them
Old Mar 20, 2020 | 04:20 AM
  #810
bforsik's Avatar
Which colour is this? Sherwood green?
Old Mar 23, 2020 | 12:48 AM
  #811
X300exec's Avatar
I made these lambs wool over rugs ,getting two scissor blisters on the way 🤦‍♂️
then got under the car to Underseal it and found two holes near the inner sill joint each side 🤮
off to be welded later this week 🤦‍♂️
Oh yeah baby
Old Apr 5, 2020 | 07:01 PM
  #812
I found the cruise control actuator bellows had a small tear this week. I started looking for a replacement and thought I should have a go at a repair, nothing to lose.
Managed to prepare a piece of bicycle inner tube as a patch and secured it down with some red RTV gasket sealant. It is flexible and holds a vacuum.
I noticed the kick down now happens almost immediately now as opposed to what was only a momentary delay before.
Seems to be working fine for now, will see how long it lasts
Bicycle inner tube seems to have the right amount of flex
Old Apr 29, 2020 | 12:49 PM
  #813
Today I replaced the Intake Air Temperature Sensor.
The original one was showing anything between 10-50 degrees Fahrenheit above ambient sensor and relative outside temps. The readings were hugely erratic, which seemed to cause a drop in MPG.
After a brief test drive, it looks like I have might regained around 5 MPG, but will be monitoring the sensor, STFT, LTFT in the coming weeks.
At the very least the idle and acceleration seem to be a lot smoother and consistent.
Old May 17, 2020 | 10:20 AM
  #814
Parker 2's Avatar
The inlet air temp sensor and the coolant temp sensor share the same response graph
See page 78 and 86
http://www.jagrepair.com/images/Training%20Guides/801S%20-%202000.pdf
Swapable ?
Old May 17, 2020 | 10:48 AM
  #815
X300exec's Avatar
Injected my silks with bilt hambner wax and taken wheel arch guards off and found no rust at all lol
cleaned front springs a bit and sprayed them with black plastic paint to tidy them up and then fitted a new cd changer which works and a phone holder
,also a nice jaguar tool kit a friend gave me for the boot 👌🏻
Old May 17, 2020 | 11:05 AM
  #816
Hi Parker 2,
The Intake Air and Coolant temp sensors are different though. The coolant sensor is contained within the solid metal end and the intake sensor has holes to allow air to flow over the sensor.
The replacement intake air sensor I have seems to read at least 10 degrees hotter than the ambient air sensor though. I was wondering if this is normal or if I have bought a faulty sensor.
This doesn't seem to affect anything though as the engine is running really well.
I am now looking at voltage drops from 14.5 to 12 then jumps back to 14.5, which seems to suggest the system is defaulting to the battery for power. I am going to check the alternator in particular the ground today and see if that makes a difference. I suspect some more investigation into the alternator is needed though.
Old May 17, 2020 | 03:00 PM
  #817
Parker 2's Avatar
14.5 is on the high side and there is a possibility that the ECU can not work with it to deliver a 5.0 reference voltage to the engine regulation sensors
Clean the small round connector on the alternator or just pull off and on several times when not lubed yet
The alternator has very robust bearings and brushes observed from a couple of X300s tinkerd with
The voltage regulator is a IN435 as a high response rate version
https://store.alternatorparts.com/in...regulator.aspx
The X300 only uses only 2 wires on the round connector and verifying pin pin letter codes
A terminal screw attaching the regulator to the brush assembly may be fused stuck so ordering a brush assembly may be prudent
The brush clamps at point F and B
https://store.alternatorparts.com/ni...-assembly.aspx
The alternator B + cable ties into the starter solenoid as a short cable and the next cable carries on to a large insulated positive post on the right finder wheel wall from the hood open side
See page 50 as the Blue / White wire is the reference voltage wire on the IATS
Papa Indy 105-11 pin on the ECU is your 5.0 reference voltage
http://www.jagrepair.com/images/AutoRepairPhotos/jagxj1997.pdf
Not all production #s have the fuel tank pressure sensor
Old May 17, 2020 | 06:10 PM
  #818
Scarecrow's Avatar
Got a new bike to keep her company in the garage before I got rid of the other one.
Old May 18, 2020 | 03:49 PM
  #819
Hi Parker 2,
Thanks for the info on the voltage regulator.
I only had time to check the engine bay grounds which didn't look too corroded, but I gave them a clean anyway. After a test drive it seems to be now relatively stable around 14.3 volts and varying between 14.5 and 13.2 volts.
I don't know the history of my alternator so I will plan to give it a clean up and check the connectors as you suggested. If that doesn't help, than I will look to replace the regulator and brushes.
TBC.
Old May 18, 2020 | 05:05 PM
  #820
Parker 2's Avatar
I didn't have any luck getting the IN435 regulator cheaper with Ebay vendors as they ( 2 ) would send me the slower response version ( stamped IN225 or something ) that would also fail in more ways on the test bench then the original regulator
My opinion is the brick store vendor has their future invested in getting you the correct and reputable part
